Finally 20's!
travis9935
If you'd be so kind as to indicate the tires your running ;)
I myself are about to put 20's on (being shipped)
Debating on 235's or 245's.
Thanks!
235 or 245 is too simplified... It will depend on what aspect ratio you go with (the second number in the tire size). Most (probably all) tire manufacturers should have a table showing what width wheels can be safely used for each tire size they offer. I would look for the tires you want and check the manufacturer's website. Obviously you'll also want to try and keep the same overall rolling diameter of the tire to avoid speedo calibration issues.
An example table....
http://www.yokohamatire.com/tires_101/customizing/rim_wheel_width/
