spankyshay Posted February 15, 2009 Report Share Posted February 15, 2009 Has anyone had luck burning MP3 DVDs that are compatible with the REQ factory stereo? Everything I've tried has resulted in a read error. I've tried session and mastered discs. I've tried DVD-R and DVD+R. Any suggestions would be appreciated. BTW: I apologize if this topic has been covered. The search function doesn't allow search terms under 4 characters so MP3 and DVD were out! Quote Link to comment Share on other sites More sharing options...
markrein Posted February 20, 2009 Report Share Posted February 20, 2009 Has anyone had luck burning MP3 DVDs that are compatible with the REQ factory stereo? Everything I've tried has resulted in a read error.I've tried session and mastered discs. I've tried DVD-R and DVD+R. Any suggestions would be appreciated. BTW: I apologize if this topic has been covered. The search function doesn't allow search terms under 4 characters so MP3 and DVD were out! Yeah. My mp3 DVD's work just fine in the player.. i am using DVD+R disks. Cheers,Marko Quote Link to comment Share on other sites More sharing options...
Remline Posted February 25, 2009 Report Share Posted February 25, 2009 Has anyone had luck burning MP3 DVDs that are compatible with the REQ factory stereo? Everything I've tried has resulted in a read error.I've tried session and mastered discs. I've tried DVD-R and DVD+R. Any suggestions would be appreciated. BTW: I apologize if this topic has been covered. The search function doesn't allow search terms under 4 characters so MP3 and DVD were out! I have the REN radio and DVD+R works fine on that one. I used Roxio on a single session. One thing to note if you put multiple folders out there you will get multiple playlists. I found it useful to put each artist in a seperate folder so you will get mulitple playlists and easier erasing of songs/artists. Quote Link to comment Share on other sites More sharing options...
Philster Posted December 31, 2009 Report Share Posted December 31, 2009 I have the REN radio and DVD+R works fine on that one. I used Roxio on a single session.One thing to note if you put multiple folders out there you will get multiple playlists. I found it useful to put each artist in a seperate folder so you will get mulitple playlists and easier erasing of songs/artists. When you say you used Roxio on a single session what do you mean? I guess I'm after which option you chose (ie: create audio disc) and roughly how many songs fit on to a DVD? I also just noticed you have a different radio. Phil. Quote Link to comment Share on other sites More sharing options...
