drphil Posted February 21, 2009 Report Share Posted February 21, 2009 My daughter has somehow pulled the pull-tab off the seat and we cannot figure out how to open the compartment under the front passenger seat now. Any suggestions or advice? Thanks, Steve Quote Link to comment Share on other sites More sharing options...
Ungrateful Posted February 23, 2009 Report Share Posted February 23, 2009 drphil said: My daughter has somehow pulled the pull-tab off the seat and we cannot figure out how to open the compartment under the front passenger seat now. Any suggestions or advice?Thanks, Steve Hi Steve, I had this happen only folded under not pulled off. If you reach under the passenger seat from behind (2nd row) in the center you will find a latch. Pull the hook part towards you and it will release. Good luck. Also, it helps to have someone help you by lifting the cushion up while you release the latch. Quote Link to comment Share on other sites More sharing options...
drphil Posted March 3, 2009 Author Report Share Posted March 3, 2009 Ungrateful said: Hi Steve,I had this happen only folded under not pulled off. If you reach under the passenger seat from behind (2nd row) in the center you will find a latch. Pull the hook part towards you and it will release. Good luck. Also, it helps to have someone help you by lifting the cushion up while you release the latch. that indeed worked...thanks! steve Quote Link to comment Share on other sites More sharing options...
