BobbyCorser Posted May 11, 2014 Report Share Posted May 11, 2014 My 2010 Journey has an REU unit that was working for a bit and then just stopped. I can hear the HD running and will occasionally see the screen blink. I had it randomly come on and then stayed off when I started the car again. Any ideas to how to get it to work ? Would disconnecting the battery and then reconnecting help ? Any suggestions would be great ! Quote Link to comment Share on other sites More sharing options...
DTSGUY Posted May 11, 2014 Report Share Posted May 11, 2014 Yes you can try disconnecting the battery. The battery isn't easy to get to but there is an easy disconnect location in the engine bay. Quote Link to comment Share on other sites More sharing options...
BobbyCorser Posted May 11, 2014 Author Report Share Posted May 11, 2014 Where is the disconnect ? Quote Link to comment Share on other sites More sharing options...
DTSGUY Posted May 11, 2014 Report Share Posted May 11, 2014 When you open the hood you will see a positive connection close to the fire wall on the driver side. Quote Link to comment Share on other sites More sharing options...
BobbyCorser Posted May 11, 2014 Author Report Share Posted May 11, 2014 Thank you. Wasn't sure if that was a disconnect or just a jumper point. Quote Link to comment Share on other sites More sharing options...
DTSGUY Posted May 11, 2014 Report Share Posted May 11, 2014 After you disconnect it check to make sure the radio doesnt turn on just to be sure. Quote Link to comment Share on other sites More sharing options...
BobbyCorser Posted May 12, 2014 Author Report Share Posted May 12, 2014 Did the disconnect and it didn't restart the computer or hard drive... Checked the fuses again... Those all look great. Trying to find out what the next option is. Quote Link to comment Share on other sites More sharing options...
