Carbon Fiber Grill Insert
Check out the sweetness of this cool little mod.
http://www.aliexpress.com/item/14-2013-dodge-Journey-China-cross-stickers-imitate-paper-modified-carbon-fiber-special-face-sticker-before/1693644320.html
If your a fan of carbon fiber, this should tickle your fancy.
EXACTLY what i intended to do to my grille, now much easier ;)
Edited by DJSXT14
You could probably get a roll of this stuff several feet long for half the price and just cut it out by yourself. That being said... The product description is great! Ha! What?
Applicable models: the dodgers cool wei warm prompt: such as dry stick, not sure good, please use water sticker, such as dry stick is out of order, we shall not be responsible for. Water stick method: first of all, will be the rear brake lamp to wipe clean. Will decorate detergent water, watering can to bottom paper of stickers, would just put detergent spray water on the sticker, then stick sticker on the rear brake lamp, adjust the position, the sticker inside of the water drain, edges if there is not adhere to, using lighter heat press close to, paste, within a few hours don't drive as far as possible, in order to avoid glue not dry, the sticker falls off.
Hahaha, i agree! I re-read it to make sure i wasnt seeing things. It's suspect, but, um $18, i can depart with. The carbon fiber roll, 24 x 48 in size goes for about $15. If this turns out to be a pre-cut fit to match, then im game. Ordered and on its way.
Oh, and they call the Journey JCUV in Asia??
Edited by DJSXT14
Probably "Journey Crossover Utility Vehicle"??? Who know, after reading the description I think that is pretty close for these guys. Ha!
I guess my thought was if you had a roll you would have a bunch extra for other projects if you wanted. The center cross in the grill is removable, so cutting it fit should be pretty easy theoretically...
