2009 shuts off while driving
Was the ignition switch recall done? If you have a wack of keys hanging from the fob it can cause the key to turn just enough to kill the ignition . . . . the solution is to put in a stronger spring, but it is even easier just to remove all that mass that causes the problem in the first place.
As to the leak? If you aren't handy take it to a responsible mechanic for a diagnosis.
Have the dealer check for any open (uncompleted) recalls. As I recall there was a recall concerning the engine abruptly shutting off. I believe I had it done on our '10 Journey. It involved the ignition - a very simple fix.
The coolant leakage is a totally different issue. If it is still under warranty have the dealer look at it. If not, I suggest having it checked at your favorite local shop.
Edited by Doug D
