Brucebotti Posted June 8, 2014 Report Share Posted June 8, 2014 After 20 months / 24,000 miles, I have my first problem with my 2012 Journey SXT. I have the standard stereo with Satelite, am/fm, and cd. I had sirius for a year, but didn't renew it. All was well until a few weeks ago when Sirius had free service for a week or so. It was working fine on my way to work Thursday, when it went silent and "Acquiring Signal" showed up on the display. Now, whenever I change the channel to AM, FM, Or CD, it plays for about 15 seconds and then immediately changes back to Sirius and the "Acquiring Signal" display. Even if I turn it off, it only stays off for 15 seconds, and then tirns itself back on and to the"Acquiring Signal" display. Has anyone had this problem before? I'm not even sure if it is a Sirius or a Dodge Issue. I just disconnected the battery and will see what happens when I hook it back up. Thanks, Bruce TracyH 1 Quote Link to comment Share on other sites More sharing options...
Brucebotti Posted June 14, 2014 Author Report Share Posted June 14, 2014 I just wanted to follow up and let everyone know that my issue has been resolved. Disconnecting the battery overnight did the trick. When I hooked it back up, everything worked as it should. Not sure what caused it, but I am happy that I didn't have to go to the dealer. Bruce TracyH and rolly 2 Quote Link to comment Share on other sites More sharing options...
rolly Posted June 14, 2014 Report Share Posted June 14, 2014 I just wanted to follow up and let everyone know that my issue has been resolved. Disconnecting the battery overnight did the trick. When I hooked it back up, everything worked as it should. Not sure what caused it, but I am happy that I didn't have to go to the dealer. Bruce Thanks for the info! Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCACares Posted June 16, 2014 Official Dodge Support Report Share Posted June 16, 2014 Thanks for the info! @Brucebotti, Great info, thanks for sharing this feedback. Seems the system reset did the trick! Cheers Quote Link to comment Share on other sites More sharing options...
Mag2274 Posted June 16, 2014 Report Share Posted June 16, 2014 I just wanted to follow up and let everyone know that my issue has been resolved. Disconnecting the battery overnight did the trick. When I hooked it back up, everything worked as it should. Not sure what caused it, but I am happy that I didn't have to go to the dealer. Bruce Thank you so much for the info! I have been having this problem when ever I accidently use the steering wheel controls to switch between the radio amd my iPod. Usually it resests after shutting off the car but this last time it stuck even over night. Quote Link to comment Share on other sites More sharing options...
