Joe Lawson Posted June 20, 2014 Report Share Posted June 20, 2014 i have a 2009 dodge journey 2.0(i'll check on that to make sure) the engine light has been on for a few weeks not. it is not running or doing anything differently than normal. i tried the key on-off-on-off-on and no codes appeared. i took the car to auto zone and they tried pulling codes as well but the reader said "no codes" just curious if someone else had run into this before. any help would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
Rgwog Posted June 21, 2014 Report Share Posted June 21, 2014 Just from what I have dug up check to make sure your gas cap is seated properly, or that computer system may have a glitch in it and will need to be flashed. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 21, 2014 Report Share Posted June 21, 2014 If the CEL is on, there should be a code, as thats the only thing that normally would make it come on. Try disconnecting the battery for awhile to reset everything and see if that makes the light go off. As stated, otherwise it could be a computer malfunction. FYI, I do not believe the key on-off thing works on OBD2 vehicles, you probably need an actyal code reader. Quote Link to comment Share on other sites More sharing options...
Joe Lawson Posted June 23, 2014 Author Report Share Posted June 23, 2014 thanks a lot guys. my first thought was the gas cap but that doesnt seem to be the case. ill try disconnecting the battery when its not raining tomorrow and post back here with the results in case anyone has this problem in the future. Rgwog 1 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted June 24, 2014 Report Share Posted June 24, 2014 On 6/23/2014 at 11:58 PM, Joe Lawson said: thanks a lot guys. my first thought was the gas cap but that doesnt seem to be the case. ill try disconnecting the battery when its not raining tomorrow and post back here with the results in case anyone has this problem in the future. Don't quote me on this, but if it were the gas cap I think there is an actual "Gas Cap" message on the newer Dodges... If not, it takes a few key cycles with driving before it will reset. Regardless, there should be a code unless it was erased. Quote Link to comment Share on other sites More sharing options...
Sparkyssxt Posted November 20, 2014 Report Share Posted November 20, 2014 Evap system minor leak or massive leak. You would have one of those from a loose/worn out gas cap Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted November 20, 2014 Report Share Posted November 20, 2014 On 11/20/2014 at 10:53 AM, Sparkyssxt said: Evap system minor leak or massive leak. You would have one of those from a loose/worn out gas cap Looks like the OP hit it and quit it on this one... only 2 posts and they are both in here. Quote Link to comment Share on other sites More sharing options...
dhh3 Posted November 20, 2014 Report Share Posted November 20, 2014 SOP for most forums. OP asks a question, then fixes it himself, and never re-posts the fix. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Sparkyssxt Posted November 21, 2014 Report Share Posted November 21, 2014 I've been buzzing through so many posts the last few days I haven't even bothered looking at the dates they were posted. Just throwing my 2c in wherever I thought it may be useful Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted November 21, 2014 Report Share Posted November 21, 2014 On 11/21/2014 at 9:15 AM, Sparkyssxt said: I've been buzzing through so many posts the last few days I haven't even bothered looking at the dates they were posted. Just throwing my 2c in wherever I thought it may be useful I've noticed! Ha! Lots of oldies popping up lately with your name all over them! At least you are adding to the conversation and posting useful information... some people do this and don't add anything. They say something like, "yeah, me too." and then we have to look through 80 posts with nothing useful added to them. Way to buck the trend! dhh3 1 Quote Link to comment Share on other sites More sharing options...
