Brian Hale Posted June 28, 2014 Report Share Posted June 28, 2014 Will a 2011-2014 grille fit a 2010? Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted June 28, 2014 Report Share Posted June 28, 2014 Yes it will. There are a few threads that discuss the grille conversion....here is one of them: http://www.dodgejourneyforum.com/topic/2418-2011-honeycomb-grille/?hl=grille Quote Link to comment Share on other sites More sharing options...
price9714 Posted March 1, 2015 Report Share Posted March 1, 2015 How hard is it to remove the grill for painting ?? Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted March 2, 2015 Report Share Posted March 2, 2015 Removal REMOVAL UPPER PUSHPINS Release hood latch and open hood. Remove the pushpins for the fascia (2) at the radiator support. POP RIVETS Hoist and support vehicle on safety stands. (Refer to Vehicle Quick Reference/Hoisting - Standard Procedure), for proper hoisting and jacking procedures. Remove the pop rivets (2) at the wheel well opening. TABS/BRACKET Remove the torx® screw (3) at the wheel well housing. Separate the fascia tabs (2) at the bracket (1). LOWER PUSHPINS Remove the pushpins (1) for the fascia (2) at the lower closeout panel. SLIDE MOUNT Slide the fascia (2) out from the mounting tab (1) under the headlamp. Disengage fog lamp wire connector and side marker connector from body harness, if equipped. Disengage the ambient temp sensor wire connector, if equipped. Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted March 2, 2015 Report Share Posted March 2, 2015 Removal REMOVAL LOWER FASCIA Remove fasteners (5) to lower closeout. CLOSEOUT- FRONT LOWER FASCIA Quote Link to comment Share on other sites More sharing options...
dhh3 Posted March 2, 2015 Report Share Posted March 2, 2015 My Nitro was like that. On and off in less than five minutes. Looks like Dodge is going backwards on this one! Does anyone know if the Blacktop and Crossroad grills are the same? Just curious. Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted March 2, 2015 Report Share Posted March 2, 2015 those instructions are a bit misleading... you don't need to remove the bumper. ltdjourney and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
