300C K&N Typhoon SRI, on journey 2013.
If you really want an SRI, I have found a NOS k&n typhoon kit for Chrysler 300 5.7l and buy it to make "test" and it fit without cut or grind something. I just need to figure how to put the heat box shield.
Edited by 5zigen
It will be interesting to see installation and results.
Chrysler VVT engines are hard to coax more hp out
because of the computer driven tune,you may experience
better gas consumption due to less restriction along with
more noise because of draw down.
Most of todays cars have cold air intakes from the factory
at least cooler than under hood air so if you can capture airflow
from factory inlet path you may gain better performance.
It's what i have find, in Stock at a very low price. 60% off. For the moment the heat box shield is not there, i need to figure how I put them to replace the oem one and take the air from the front. But just like this, I see quicker response and the engine seem to be have something more at 1k to 2500k-4k to top end.
