Red G8R Posted July 28, 2014 Report Share Posted July 28, 2014 (edited) So another problem I've encountered this past weekend is with trickle charging my new Journey. Basically I've parked it for the next two months so I attach an automatic battery trickle charger (2A) only to notice that the dash info center (between the gauges) lights up saying "press brake pedal to start" plus the ignition button light is also on. Yet the car is locked and I'm outside the car. Any clues? I've never encountered this with my other cars. Edited July 28, 2014 by Red G8R Quote Link to comment Share on other sites More sharing options...
jkeaton Posted July 28, 2014 Report Share Posted July 28, 2014 (edited) I dont even know if newer vehicles support "trickle charging'. There are so many electronics and computers and such. It probably thinks the engine is running since the battery voltage is being a bit "boosted" by the charger. It might be a pain, but you might have to disconnect the negative battery terminal to isolate the battery from the cars electronics. Edited July 28, 2014 by jkeaton Quote Link to comment Share on other sites More sharing options...
