leslynn Posted March 12, 2009 Report Share Posted March 12, 2009 I have an SXT AWD with the large tires (19 inch). When turning tight at slow speeds, I can hear the tires (I think) rubbing on the inside of the fender. It happens in either direction. I have not noticed any shiny spots in the fender or any wear on the tire but this is enough to concern me. Any thoughts?? Quote Link to comment Share on other sites More sharing options...
Sam Posted March 12, 2009 Report Share Posted March 12, 2009 Maybe it is the power steering pump that you're hearing... Quote Link to comment Share on other sites More sharing options...
JourneyMan71 Posted March 12, 2009 Report Share Posted March 12, 2009 I have the Front wheel drive SXT and I can hear something like a tire rub sometimes when I back out and turn the wheel. I am not sure what it is, but I will investigate and post what I find out. Quote Link to comment Share on other sites More sharing options...
noren Posted March 13, 2009 Report Share Posted March 13, 2009 Sam said: Maybe it is the power steering pump that you're hearing... I noticed that yesterday. Why is it that the power steering pump makes that loud noise when you turn the steering wheel completely to the left or right. /Andreas Quote Link to comment Share on other sites More sharing options...
Sam Posted March 13, 2009 Report Share Posted March 13, 2009 If it is very loud, you have air in the system. This was a common problem at first with the Journey. The dealer had to eliminate the air in the power steering system and in some cases, change the tank for a bigger. Look there, you'll have all the information and the number of the service bulletin on the last page: http://www.dodgejourneyforum.com/index.php...40&start=40 Quote Link to comment Share on other sites More sharing options...
WOLF Posted March 18, 2009 Report Share Posted March 18, 2009 a power steering pump, will make a lot of noise when the steering is on full lock, due to trying to pump fluid, when it is unable to do so!!!! think about it folks, you can only get so much fluid to fit into one end of a cylinder at a time, any more and it would leak, and so the pump strains and the bypass valve (if one is fitted) will come in to play, until you turn the steering again!! not having had a chance to look, i am not 100% sure what sort of system is fitted to the Journey, but they all work basically the same.... Quote Link to comment Share on other sites More sharing options...
noren Posted March 19, 2009 Report Share Posted March 19, 2009 WOLF said: a power steering pump, will make a lot of noise when the steering is on full lock, due to trying to pump fluid, when it is unable to do so!!!! think about it folks, you can only get so much fluid to fit into one end of a cylinder at a time, any more and it would leak, and so the pump strains and the bypass valve (if one is fitted) will come in to play, until you turn the steering again!! not having had a chance to look, i am not 100% sure what sort of system is fitted to the Journey, but they all work basically the same.... Although other people on the forum have had problem with the power steering. The previous post explains my question. This is what I have experienced and is in this case perfectly normal if I have understand it correctly. /Andreas Quote Link to comment Share on other sites More sharing options...
sdeveau Posted April 29, 2009 Report Share Posted April 29, 2009 I have a FWD SXT w/ 19" wheels. I have a groaning noise only when I turn left. Now my dealership told us this is normal...but apparently so are computer glitches so.... I think read something as well about replacing the tank for one bigger and it should fix the problem. Quote Link to comment Share on other sites More sharing options...
Remline Posted April 29, 2009 Report Share Posted April 29, 2009 sdeveau said: I have a FWD SXT w/ 19" wheels. I have a groaning noise only when I turn left. Now my dealership told us this is normal...but apparently so are computer glitches so....I think read something as well about replacing the tank for one bigger and it should fix the problem. There is a recall on the Powersteering pump for just that problem. Quote Link to comment Share on other sites More sharing options...
jatty21 Posted April 30, 2009 Report Share Posted April 30, 2009 I just had mine in for an oil change and there were 2 recalls, one was the Steering Reservoir and the other was a Break sensor. I notice a HUGE difference in steering now and no 'rubbing noise' anymore. Quote Link to comment Share on other sites More sharing options...
CountryGirl2 Posted January 24, 2010 Report Share Posted January 24, 2010 We have the FWD SXT w/ 19" wheels as well and no noise or rubbing going on with our Journey... Quote Link to comment Share on other sites More sharing options...
Elmwoodie Posted July 1, 2010 Report Share Posted July 1, 2010 AWD RT w/ 19" wheels and no noise or rubbing going on with our Journey. But compared to our 2006 Equinox, it sure dont turn tight. I hate passing by all those good parking spots that I dont have the maneuvaribility (and smaller size) to enter. Elmwoodie. Quote Link to comment Share on other sites More sharing options...
DJK09SXT Posted December 9, 2010 Report Share Posted December 9, 2010 While test driving my 09 SXT I noticed some noise coming from the pump. I made a deal with my Dodge salesman to have the pump replaced if I bought the car. He agreed, and the car was serviced about a month later. Granted I bought my car in the middle of winter in North Dakota. I believe it was minus 20F so everything makes noise in that cold climate. Since having the power steering pump replaced, I only notice a little noise when the temperature is 30F or cooler. It sits in the garage all night so no problems getting to someplace, only after it has sat outside for a few hours and cooled off I notice a slight noise on my way home. I will say I am impressed with the cars turning radius. I an running 225/65/17 Firestone Destination LE. Awesome tire, great on this FWD car. No rubbing. Had some snow/slush on the roads a few times, no problem. Quote Link to comment Share on other sites More sharing options...
