The "Won't Start" issue rears its ugle head, once again.
trevcda
My DJ has 111,000 miles on it. Recently had the original battery go belly up. That's fun to change! Anyway it would occasionally not start and shortly after that it became a little more frequent. The electronics all fire up and if I had to describe it, I would say that it sounds like the starter throws out but does not turn. Electronics, click, nothing, electronics. What is the expected life span of the started on that engine? R/T FWD.
It really depends on how often you cycle it... have someone try and start it and crawl underneath and whack the starter with a mallet. If it starts then it is very likely your culprit. Seems early to me though, maybe the battery install left a wire not cinched down properly or there is corrosion on a terminal or ground somewhere? I would check all of those too...
Thanks for the suggestions. No corrosion around the battery, jump start or distribution box. Haven't check other points like starter or straps, if there are any. Haven't tried anything to do with the transmission, but will check next time it happens.
I would check connections at the starter as well...
