LFSoccer2k6 Posted August 20, 2014 Report Share Posted August 20, 2014 Will the 2011+ LED taillight assemblies fit a 2009? Thanks Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted August 20, 2014 Report Share Posted August 20, 2014 I recall a post saying it did... however there is a lot more to the swap then just putting the assembly in. Quote Link to comment Share on other sites More sharing options...
LFSoccer2k6 Posted August 20, 2014 Author Report Share Posted August 20, 2014 I recall a post saying it did... however there is a lot more to the swap then just putting the assembly in. Oh yea I bet wiring is a pain. However if the housings fit, wiring can usually be managed in some fashion. lorinclark88 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted August 20, 2014 Report Share Posted August 20, 2014 Here is one thread with additiona info: http://www.dodgejourneyforum.com/topic/5276-bubble-tail-lights/?hl=taillights Quote Link to comment Share on other sites More sharing options...
dhh3 Posted August 21, 2014 Report Share Posted August 21, 2014 (edited) The ballast is built into the tail light housing. If you have a connector that has 3 wires: white with a silver stripe, white and black, they should plug right in and work. For 2014, the incandescents bulbs are still available on the lowest priced DJ. I highly doubt if there are 2 distinct wiring harnesses. I pulled my connector off of my left rear LED: 12v at the connector which is why I believe that the ballast that reduces the voltage for the LEDs is built into the housing. Edited August 21, 2014 by dhh3 Quote Link to comment Share on other sites More sharing options...
