in dash u connect system
You need the 8.4 radio unit with or without navigation is up to you, but for the nav to work you need to have SIRIUS already installed on your 4.3 unit otherwise you need to purchase an additional antenna for the GPS signal to work, also you need the touch screen, the dash bezel should be OK.
is all plug and play if you purchase a 2011 unit you don't need an unlock code if you purchase a 2012 or 2013 unit you need to know the VIN number of the donor car.
