jojogg Posted August 28, 2014 Report Share Posted August 28, 2014 I know the part number for the brake is 68144163AE. however I do not know exact part number for Rotor. 2013 Dodge Journey front brake Thanks Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCACares Posted August 28, 2014 Official Dodge Support Report Share Posted August 28, 2014 I know the part number for the brake is 68144163AE. however I do not know exact part number for Rotor. 2013 Dodge Journey front brake Thanks jojogg, I've identified two different part numbers which are for front rotors on a 2013 Dodge Journey. 68192969AA 04779712AA I would suggest speaking with the Part dept. at your local Dodge store though. They'll be sure to check your VIN and provide you with the most accurate info. Quote Link to comment Share on other sites More sharing options...
jojogg Posted August 28, 2014 Author Report Share Posted August 28, 2014 (edited) I will buy the rotor from the ebay which will be cheaper. So I do not know if they like to tell or not. thank you. jojogg, I've identified two different part numbers which are for front rotors on a 2013 Dodge Journey. 68192969AA 04779712AA I would suggest speaking with the Part dept. at your local Dodge store though. They'll be sure to check your VIN and provide you with the most accurate info. Edited August 28, 2014 by jojogg Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted August 28, 2014 Report Share Posted August 28, 2014 I will buy the rotor from the ebay which will be cheaper. So I do not know if they like to tell or not. thank you. You're better off going aftermarket anyway... But, if for some reason you are compelled to use Mopar parts then you can usually get a much better deal from an online wholesaler. I would be careful on eBay. Quote Link to comment Share on other sites More sharing options...
jojogg Posted August 28, 2014 Author Report Share Posted August 28, 2014 I checked the brake pad and found that the one used on my car is larger than normal brake pad. The dealler explained that it is heavy duty design. I am not sure if there are some simmliar one aftermarcket. I will check it in CT anyway. Thank you. You're better off going aftermarket anyway... But, if for some reason you are compelled to use Mopar parts then you can usually get a much better deal from an online wholesaler. I would be careful on eBay. Quote Link to comment Share on other sites More sharing options...
Milous Posted August 29, 2014 Report Share Posted August 29, 2014 however I do not know exact part number for Rotor. 2013 Dodge Journey front brake 68192969AA is the original part number. 04779712AA is the new part number (which supersedes 68192969AA). Quote Link to comment Share on other sites More sharing options...
jojogg Posted August 29, 2014 Author Report Share Posted August 29, 2014 Thank you Milous. Is this 04779712AA perfectly fit with 68144163AE? 68192969AA is the original part number. 04779712AA is the new part number (which supersedes 68192969AA). Quote Link to comment Share on other sites More sharing options...
Milous Posted August 29, 2014 Report Share Posted August 29, 2014 (edited) Thank you Milous. Is this 04779712AA perfectly fit with 68144163AE? Yes; it's the preferred/recommended replacement part (68192969AA is no longer orderable). btw, U.S. MSRP is $118.00 ea. ($70.70 dealer). Canada = $160.00 ea. ($95.45 dealer). Edited August 29, 2014 by Milous Quote Link to comment Share on other sites More sharing options...
jojogg Posted August 29, 2014 Author Report Share Posted August 29, 2014 Thank you, Milous Yes; it's the preferred/recommended replacement part (68192969AA is no longer orderable). btw, U.S. MSRP is $118.00 ea. ($70.70 dealer). Canada = $160.00 ea. ($95.45 dealer). Quote Link to comment Share on other sites More sharing options...
