Nunezdea Posted October 4, 2014 Report Share Posted October 4, 2014 The tire pressure light for one of the tires(" (front driver side) keeps switching between 36 psi and 0 psi. Any suggestions? Is the pressure sensor easy to replace without mayor tools? Quote Link to comment Share on other sites More sharing options...
bigtsr Posted October 4, 2014 Report Share Posted October 4, 2014 You may have a TPMS receiver failure and not necessarily the in tire sensor assy. In past Chrysler there have been 2 receivers in the front and 1 for the rear tires I am not sure if this has changed on 2011 and up but the receivers should be reachable and the in tire sensor assy requires tire removal. Make sure you get the right frequency when replacing parts. Quote Link to comment Share on other sites More sharing options...
