Guajardo Family Posted October 7, 2014 Report Share Posted October 7, 2014 I'm a little frustrated. Seems right when my warranty is up things seemed to mess up. Looking on this forum i believe i fall under these two TSB's. My question is do i have to have warranty to fix these or will i have to pay. Someone please help. Check engine light just came on and got it checked and this came up "P0441-EVAP PURGE SYSTEM PERFORMANCE" I bought a chrysler extended warranty when i got it does anyone know when that expires. I have a 2012 Dodge Journey SE. Purchased in Sept. of 2011. 2.4L Engine. NUMBER: 18-004-12GROUP: Vehicle PerformanceDATE: January 28, 2012THIS SERVICE BULLETIN IS ALSO BEING RELEASED AS RAPID RESPONSETRANSMITTAL (RRT) 12-006. ALL APPLICABLE SOLD AND UN-SOLD RRT VIN'sHAVE BEEN LOADED. TO VERIFY THAT THIS RRT SERVICE ACTION ISAPPLICABLE TO THE VEHICLE, USE VIP OR PERFORM A VIN SEARCH INTECHCONNECT. ALL REPAIRS ARE REIMBURSABLE WITHIN THE PROVISIONS OFWARRANTY.THIS BULLETIN SUPERSEDES SERVICE BULLETIN 18-052-11, DATED NOVEMBER23, 2011 WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS AREHIGHLIGHTED WITH **ASTERISKS** AND INCLUDE THE ADDITION OF THE JSMODELS.HELP USING THE wiTECH DIAGNOSTIC APPLICATION FOR FLASHING AN ECU ISAVAILABLE BY SELECTING “HELP” THEN “HELP CONTENTS” AT THE TOP OFTHE wiTECH DIAGNOSTIC APPLICATION WINDOW.THE wiTECH SOFTWARE LEVEL MUST BE AT RELEASE 12.01 OR HIGHER TOPERFORM THIS PROCEDURE.SUBJECT:Flash: MIL Illumination P0441, P0300, P0301, P0302, P0303, P0304, P0305, P0306,P0420, P0430, P113D, P113E, P0133, P0153OVERVIEW:This bulletin involves selectively erasing and reprogramming the Powertrain ControlModule (PCM) with new software.MODELS:2012 (JC) Journey**2012 (JS) 200/Avenger**NOTE: This bulletin applies to **JC** vehicle equipped with a 3.6L engine (salescode ERB) built before November 15, 2011 (MDH 1115XX) or **JS vehicleequipped with a 3.6L engine (sales code ERB) built before December 16, 2011(MDH 1116XX).**SYMPTOM/CONDITION:The customer may experience a MIL illumination. Upon further investigation theNUMBER: 18-004-12GROUP: Vehicle PerformanceDATE: January 28, 2012Technician may find that any of the following Diagnostic Trouble Codes have been set.a. P0441 - Evap Purge System Performanceb. P0420 - Catalyst Efficiency (Bank 1)c. P0430 - Catalyst Efficiency (Bank2)d. P0133 - O2 Sensor 1/1 Slow Responsee. P0153 - O2 Sensor 2/1 Slow Responsef. P0300 - Multiple Cylinder Misfireg. P0301 - Cylinder 1 Misfireh. P0302 - Cylinder 2 Misfirei. P0303 - Cylinder 3 Misfirej. P0304 - Cylinder 4 Misfirek. P0305 - Cylinder 5 Misfirel. P0306 - Cylinder 6 Misfirem. P113D - O2 Sensor 1/1 Slow Response (High Frequency)n. P113E - O2 Sensor 2/1 Slow Response (High Frequency)Updating the software will correct the conditions listed above. Radio has beeb going a little hectic latey also. Saw this TSB NUMBER: 08-048-11 REV. AGROUP: ElectricalDATE: December 20, 2011SUBJECT:RHA And REB Radio Software EnhancementsOVERVIEW:This bulletin involves upgrading the software on the RHA or REB Radio.MODELS:2011-2012 (JC) Journey**2011-2012 (LD) Charger**NOTE: This bulletin applies to JC vehicles built prior to **October 4, 2011 (MDH1004XX) and LD vehicles built prior to July 25, 2011** equipped withUCONNECT TOUCH 4.3 CD/MP3 (sales code RHA) or UCONNECT TOUCH4.3S CD/MP3/SAT (sales code REB).NUMBER: 08-048-11 REV. AGROUP: ElectricalDATE: December 20, 2011SYMPTOM/CONDITION:· **When the ignition is first turned on, the audio volume is very high.**· **CD audio glitch and/or audio drop out for 0.2 seconds.**· No display and no audio on radio.· The driver's heated seat soft key is grayed out on the radio display.· CD skips repeatedly while playing.· CD jumps tracks after cranking the engine, turning the radio off and then on, and/orafter depressing the stop and then play soft key.· In USB playback mode a blank screen, or the last displayed screen, is displayedwhen the ABC soft key is pressed.· An iPod Nano connected in USB mode may fail to play and/or the Pause and Playkeys are reversed on the radio display.· Multiple instances of the same Sirius Game Zone entry may be displayed.· Intermittently, the back-up chime sounds continuously once vehicle is put intoforward gear, instead of shutting off.DIAGNOSIS:If a customer’s VIN is listed in VIP or your RRT VIN list, perform the repair. For all othercustomers that describe the symptom/condition, perform the Repair Procedure.PARTS REQUIRED:Qty. Part No. Description**AR (1) 68147629AB REB Update Disc (version 11.41.6) for JC****AR (1) 68147630AB RHA Update Disc (version 11.41.6) for JC****AR (1) 68169945AA REB Update Disc (version 11.40.6) for LD****AR (1) 68169943AA RHA Update Disc (version 11.40.6) for LD** Link to comment Share on other sites More sharing options...
Lobitz68 Posted October 7, 2014 Report Share Posted October 7, 2014 Your warranty paperwork should list dates and mileage that it expires at... If not under warranty it really depends on the dealer. You will likely have to pay for it if it is no longer under warranty though, unless your dealer is something special. Link to comment Share on other sites More sharing options...
jkeaton Posted October 7, 2014 Report Share Posted October 7, 2014 TSB's are not covered if your warranty is expired. Link to comment Share on other sites More sharing options...
Guajardo Family Posted October 7, 2014 Author Report Share Posted October 7, 2014 Thank you guys for the help!! Link to comment Share on other sites More sharing options...
Guajardo Family Posted October 7, 2014 Author Report Share Posted October 7, 2014 Another quick question. Are dealerships the only people who can handle TSBs or can i take it to my Mechanic...sorry if its a dumb question Link to comment Share on other sites More sharing options...
jkeaton Posted October 8, 2014 Report Share Posted October 8, 2014 It would probably have to be factory authorized repair facility to perform factory TSB's. Link to comment Share on other sites More sharing options...
Lobitz68 Posted October 8, 2014 Report Share Posted October 8, 2014 Another quick question. Are dealerships the only people who can handle TSBs or can i take it to my Mechanic...sorry if its a dumb question Since these both involve software updates you would need to go to your dealer... I have seen many TSB's that could be performed by the owner or another shop though...just not this kind. Should only be like $100 to do both. I know it's not cheap, but it's not expensive either. jkeaton 1 Link to comment Share on other sites More sharing options...
Guajardo Family Posted October 8, 2014 Author Report Share Posted October 8, 2014 Thank so much Link to comment Share on other sites More sharing options...
