Power Steering Gear... Did any one change this part yet?
Hello, here in Brazil seems to be very common to replace this GEAR, Power Steering Mopar Code 05151348AC have any of you guys replaced this part? in the US around 900 dollars... here in Brazil around 5000 usd, we normally have to do a lot of suspension maintenance, my DJ 2010/2010 with 80.0000 km is presenting a blup blup sound, very common to a strut mount or joint problem or similar, but every mechanic that i take that has experience on this car first thing they say is this car present a lot of problems on the power steering gear and normally it has to be replaced, it only started on the left wheel when i was passing thru a train track, then was more often and now starting to hear on the right wheel specially when i was traveling in unpaved road....
