Cody Chornobey Powley Posted October 22, 2014 Report Share Posted October 22, 2014 K so I have all my parts needed to do my retrofit tempted to use my stock headlights I have butyl glue from my previous retrofit that I orders from TRS so no worries about condensation after the fact. Really don't want to spend more money on these lights. I already have 20 watt Cree projector led reverse 50 watts high beam LEDs just for looks cause with the projector I'll have the highbeam. I have the switchback led for turn signal and rear led turn signal are on the way in the mail. Basically spent 200 just on those lights so I don't want to sink another 2-300 on aftermarket just to open up total cost if I do that would be under 700. But has anyone baked their OEM headlight? I herd people say don't waste time on these cause they are permaseal and I'll never get them off and others I've herd of doing the oven deal. Anyone does this to their OEM lights???!!! Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted October 22, 2014 Report Share Posted October 22, 2014 (edited) TRS recommends 285 for 15 minutes... You may have to repeat. They have a video if you want to get details... EDIT: Make sure you preheat so you are actually at 285 for the full 15 minutes... Edited October 22, 2014 by Lobitz68 Cody Chornobey Powley 1 Quote Link to comment Share on other sites More sharing options...
Lawdog1911 Posted October 23, 2014 Report Share Posted October 23, 2014 Ebay has a set of DJ lights for under $130 shipped. I might pick up another set to resell . Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted October 24, 2014 Author Report Share Posted October 24, 2014 Not looking to spend more than I have to. I'll just put them in the over. Put my elantra lights in a few times without problems. But since these are permaseal I'll have to bake a few times I guess Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted October 24, 2014 Author Report Share Posted October 24, 2014 TRS recommends 285 for 15 minutes... You may have to repeat. They have a video if you want to get details... EDIT: Make sure you preheat so you are actually at 285 for the full 15 minutes... They have a video for permaseal? I could find videos for that. I found videos of people using a cutting iron but I really don't want to do that Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted October 24, 2014 Report Share Posted October 24, 2014 This video has it as a note: I couldn't find an actual video for permaseal, but Andrew from TRS points to this video when asked about permaseal. Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted October 24, 2014 Author Report Share Posted October 24, 2014 I think someone should make a video for permaseal lights, I would but I only have a tablet to use. Is the instruction on how to remove the headlight fro. The journey. I've looked at it today and seen three screws probably have to remove the front grille eh? Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted October 24, 2014 Report Share Posted October 24, 2014 you have to remove the grill, the tabs in the wheel well and two screws on each side that hold the bumper in place. after that you can pull the bumper forward a little and get pretty good access. there are 2 tabs where the wheel junts out on the bumper that you need to release as well. DTSGUY 1 Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted October 24, 2014 Author Report Share Posted October 24, 2014 Holy. Is there a reference somewhere I could use? I'm sure its not hard to figure out but just to make the process faster and easier would be nice Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted October 24, 2014 Author Report Share Posted October 24, 2014 Is there a video or photos just to reference it before I start? Quote Link to comment Share on other sites More sharing options...
Powerz69 Posted October 24, 2014 Report Share Posted October 24, 2014 It's a pain in the a$$ to get the headlights out. As for the permaseal heat and pick a corner to start working on. Try to slide a small flat blade screwdriver along the edges to loosen the permaseal up. Once you can get a 1/4 way open the rest is a lot easier. You will chew up the plastic channel but you can straighten it out very good with a heatgun after. You are thinking to much about it, since you opened headlights before it's the same just a bit longer and tougher. WEAR GLOVES! Cody Chornobey Powley 1 Quote Link to comment Share on other sites More sharing options...
Cody Chornobey Powley Posted October 25, 2014 Author Report Share Posted October 25, 2014 Think a 2010 set would fit the 14? They look the same but maybe mounting is different? Quote Link to comment Share on other sites More sharing options...
DTSGUY Posted October 25, 2014 Report Share Posted October 25, 2014 you have to remove the grill, the tabs in the wheel well and two screws on each side that hold the bumper in place. after that you can pull the bumper forward a little and get pretty good access. there are 2 tabs where the wheel junts out on the bumper that you need to release as well. That's exactly how I did mine. Quote Link to comment Share on other sites More sharing options...
DTSGUY Posted October 25, 2014 Report Share Posted October 25, 2014 Is there a video or photos just to reference it before I start? If you have FaceTime I'll show you how to do it. It's not hard at all. Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted October 27, 2014 Report Share Posted October 27, 2014 2010's will fit. Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted October 27, 2014 Report Share Posted October 27, 2014 If you have FaceTime I'll show you how to do it. It's not hard at all. Not hard, just a PAIN IN THE ASS... Cody Chornobey Powley and DTSGUY 2 Quote Link to comment Share on other sites More sharing options...
