Oil Pressure
My 2013 Journey R/T V6 oil pressure sensor pegged on Hi and had to be replaced. (It took forever to get the part).
I've been monitoring the oil pressure and find that, after warm-up, it sometimes idles at 170kpa and runs at hiway at around 250kpa.
This seems way too low for me. Any suggestions ??
OIL PRESSURE
Description
Specification
Metric
Standard
(Note: At Normal Operating Temperatures)
Pressure @ Curb Idle Speed*
34.7 kPa Min.
5 psi Min.
Pressure @ 600 - 1200 RPM
34.7 (warm) - 958.0 (cold) kPa
5 (warm) - 139 (cold) psi
Pressure @ 1201 - 3500 RPM
206.8 (warm) - 958.0 (cold) kPa
30 (warm) - 139 (cold) psi
Pressure @ 3501 - 6400 RPM
427.0 (warm) - 958.0 (cold) kPa
62 (warm) - 139 (cold) psi
*CAUTION: If oil pressure is zero at idle, DO NOT run the engine.
170 kilopascals is roughly 24.7 psi and 250 kilopascals is roughly 36.3 psi...
This seems pretty normal to me... Assuming the engine is warm during this test, you are a long ways from the unsafe area, which as Journeyman425 has stated is right around 5 psi.
