Is thermostat covered under Lifetime Power train warranty?
feenix480
Thermostat is not considered a powertrain component and as such is not covered.
Gasoline Engine:
cylinder block and all internal
parts; cylinder head assemblies; timing case, timing
chain, timing belt, gears and sprockets; vibration
damper; oil pump; water pump and housing; intake and
exhaust manifolds; flywheel with starter ring gear; core
plugs; valve covers; oil pan; turbocharger housing and
internal parts; turbocharger wastegate actuator;
supercharger; serpentine belt tensioner; seals and
gaskets for listed components only.
