Jody Aistrop Slater Posted November 21, 2014 Report Share Posted November 21, 2014 I have had problems with my DJ shutting off while I am driving. I ran over some railroad tracks the other day and everything shut off. Then it will restart itself. It did that twice then the third time it would not start. I took it to the dealer but it started fine for them and they said nothing was wrong with it. I had this problem a couple months ago and replaced the battery and alternator but now it is doing it again. I see there is a recall on the 2010 DJ for this but not the 2011. Quote Link to comment Share on other sites More sharing options...
Sparkyssxt Posted November 21, 2014 Report Share Posted November 21, 2014 Damn gremlins... Typically this would be a loose or broken wire somewhere in the engine harness. It's not a short as you would pop a fuse each time the engine died. It IS possible it's a damaged sensor but you would have a check engine light from such. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted November 21, 2014 Report Share Posted November 21, 2014 (edited) Intermittent issues are hard to diagnose. I don't take my vehicle in for service for something unless I can duplicate the problem. Edited November 21, 2014 by jkeaton Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCACares Posted November 21, 2014 Official Dodge Support Report Share Posted November 21, 2014 I have had problems with my DJ shutting off while I am driving. I ran over some railroad tracks the other day and everything shut off. Then it will restart itself. It did that twice then the third time it would not start. I took it to the dealer but it started fine for them and they said nothing was wrong with it. I had this problem a couple months ago and replaced the battery and alternator but now it is doing it again. I see there is a recall on the 2010 DJ for this but not the 2011. Jody Aistrop Slater, Welcome to the forum! I tend to agree with Sparkyssxt, a loose connection somewhere tends to cause something to cut out, especially when going over a significant bump in the road. See if you can find a set of tracks or anything bumpy nearby to your dealer and request they take a test drive with you in attempts to duplicate. Keep us posted if you can. Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted November 21, 2014 Report Share Posted November 21, 2014 I will third the wiring... You may want to find another dealer too. While I understand that they need to be able to replicate the issue in order to solve it, they should also be able to use their heads for something besides holding their ears apart. Sounds like lazy idiots that won't even attempt to THINK in order to troubleshoot. These are the worst kind of mechanics... "If the answer is not written down somewhere or there is not a code then I can't do anything about it..." Very annoying. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted November 21, 2014 Report Share Posted November 21, 2014 Maybe the ground connection on the TIPM is loose or corroded Quote Link to comment Share on other sites More sharing options...
