otavio15 Posted December 1, 2014 Report Share Posted December 1, 2014 Hi everyone. I tried to find in the forums someone that had the same problem as I have, but I had no luck to find one. I have a 2009 SXT DJ, and I live in Brazil, so we are almost on summer and it's very hot in here, so I use the a/c everyday. Yesterday I started to notice that everytime I made a left turn, I could hear something dripping inside the a/c ducts. Then, whenever I made a right turn, hot water started to leak on my foot, very hot water. But the a/c is working perfectly. I tried to find from where the water was leaking, and I could see that it came from the panel, but upwards. Can be the a/c radiator, or a blocked drain? Thanks everybody Quote Link to comment Share on other sites More sharing options...
dhh3 Posted December 1, 2014 Report Share Posted December 1, 2014 Possibly the heater core is leaking. Quote Link to comment Share on other sites More sharing options...
bigtsr Posted December 1, 2014 Report Share Posted December 1, 2014 In the past this complaint has usually been found to be the result of a plugged drain on the AC evaporator assy. The water accumulates and spills over when the car is turning and can be the cause of the musty smell when AC or defrost is used. Quote Link to comment Share on other sites More sharing options...
otavio15 Posted December 1, 2014 Author Report Share Posted December 1, 2014 Can be. It's very hot today and I had to use the AC. I noticed that there is no water leaking under the car when the AC is on, so it should be this. Where can I find instructions to access this drain and fix it? Quote Link to comment Share on other sites More sharing options...
bigtsr Posted December 1, 2014 Report Share Posted December 1, 2014 I have never checked mine but here is a pic from parts book and it is item 13 appears to exit by gas pedal. Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted December 1, 2014 Report Share Posted December 1, 2014 You'll likely need to access it from the engine bay side of the fire wall... poke it with a wire or a pipe cleaner. That should free it up. Quote Link to comment Share on other sites More sharing options...
Trains123 Posted December 2, 2014 Report Share Posted December 2, 2014 (edited) I had the same problem on my 2013. It was the AC drain hose. The dealer had to take out the whole dash and the two front seats to fix it. They found that the drain hose was kinked. They had to put in a new one. It took them 4 weeks to do it. I was sure glad the warranty covered it! Good luck!!!! Edited December 2, 2014 by Trains123 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted December 2, 2014 Report Share Posted December 2, 2014 I had the same problem on my 2013. It was the AC drain hose. The dealer had to take out the whole dash and the two front seats to fix it. They found that the drain hose was kinked. They had to put in a new one. It took them 4 weeks to do it. I was sure glad the warranty covered it! Good luck!!!! Wow... that sounds like a nightmare!! Quote Link to comment Share on other sites More sharing options...
otavio15 Posted December 2, 2014 Author Report Share Posted December 2, 2014 Thanks for the replies guys. Indeed it was the AC drain hose that was clogged. I took the car to an AC especialized mechanic and he did the job in a few hours. Charged me about $40 to do the job. Thanks! dhh3 1 Quote Link to comment Share on other sites More sharing options...
bigtsr Posted December 3, 2014 Report Share Posted December 3, 2014 Good to know it's resolved. Quote Link to comment Share on other sites More sharing options...
dhh3 Posted December 3, 2014 Report Share Posted December 3, 2014 Thanks for the replies guys. Indeed it was the AC drain hose that was clogged. I took the car to an AC especialized mechanic and he did the job in a few hours. Charged me about $40 to do the job. Thanks! Next time I need some work done I'm calling him! Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted December 3, 2014 Report Share Posted December 3, 2014 Next time I need some work done I'm calling him! probably won't save you much since he is in Brazil... Ha! Quote Link to comment Share on other sites More sharing options...
