Mikejones Posted December 11, 2014 Report Share Posted December 11, 2014 So my wife called me at work today saying every time she went over a bump it either changed the station or track of what was playing in the radio!! It's a main street and version with the 4.3". I'm pretty knowledgeable with cars but am not into messing with factory electronics these days...too much happens if you disconnect the negative haha! Thanks for any input. Quote Link to comment Share on other sites More sharing options...
bigtsr Posted December 12, 2014 Report Share Posted December 12, 2014 Sounds like a loose connection,you can do the same thing from steering wheel controls so it could be clockspring or bad connection at the radio black box. Lobitz68 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted December 12, 2014 Report Share Posted December 12, 2014 For radio issues, you need to disconnect the negative terminal for at least 1/2 hour. You will not lose any presets because the radio has a small battery to keep them. Try this. See if it works. Has worked for me numerous times in the past!. Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted December 12, 2014 Report Share Posted December 12, 2014 On 12/12/2014 at 12:37 AM, bigtsr said: Sounds like a loose connection,you can do the same thing from steering wheel controls so it could be clockspring or bad connection at the radio black box. I agree with bigstr... I would check these avenues first. Quote Link to comment Share on other sites More sharing options...
bigtsr Posted December 12, 2014 Report Share Posted December 12, 2014 Operative word was "BUMPS" and the reason for my suggestion. Quote Link to comment Share on other sites More sharing options...
Mcgusto82 Posted December 28, 2014 Report Share Posted December 28, 2014 id look at the steering wheel buttons. dhh3 1 Quote Link to comment Share on other sites More sharing options...
