HI ALL i have a 2014 dodge journey,and my drivers door has locked shut? it won't open at all,i have read it maybe a deadbolt solenoid problem,just need a little advice if anyone can help to unlock it so it can be changed if it is that,?any help appreciated,ben,
I would suggest if you can't unlock it using the inside
door switch that it's an electrical problem.
I would first try disconnecting the battery at the negative
jumper point for 10-15 minutes to reset the TIPM to see
if that is where the problem originates.
2014 model should still be covered for true electrical
problems.
