MrNevermind Posted December 20, 2014 Report Share Posted December 20, 2014 Please help, my 2009 dodge journey just dropped into limp mode after 2 days of the engine light on, i checked with obd2 reader and p2002 code came up but wont clear, ive changed air filter and was running ok till today, just dropped into limp mode when i was picking my son up from work. Is this long term till i can get car fixed as in DPF removed or is it DO NOT DRIVE CAR NOW?? Quote Link to comment Share on other sites More sharing options...
MrNevermind Posted December 21, 2014 Author Report Share Posted December 21, 2014 25 views and no help, go figure. hahaha Quote Link to comment Share on other sites More sharing options...
OhareFred Posted December 21, 2014 Report Share Posted December 21, 2014 Look in the forum, there is a thread by you that's says p2002 and limp mode with replies. Quote Link to comment Share on other sites More sharing options...
bigtsr Posted December 21, 2014 Report Share Posted December 21, 2014 The VW engine used in Europe export DJs sometimes goes into limp mode because of a bad EGR assembly according to posts I have read. There are no diesel DJs in NA that's why help regarding the engine are few and far between. 2late4u 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 21, 2014 Report Share Posted December 21, 2014 which we could get the diesel over here Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted December 21, 2014 Report Share Posted December 21, 2014 25 views and no help, go figure. hahaha You are aware you double posted this thread....did you read my post here? http://www.dodgejourneyforum.com/topic/6393-p2002-code-and-limp-mode/ 2late4u and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
2late4u Posted December 21, 2014 Report Share Posted December 21, 2014 its hard to help some people isnt it journey-sext, LOL jkeaton 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 22, 2014 Report Share Posted December 22, 2014 Please refer to your post in the other section. Quote Link to comment Share on other sites More sharing options...
dhh3 Posted December 22, 2014 Report Share Posted December 22, 2014 The VW engine used in Europe export DJs sometimes goes into limp mode because of a bad EGR assembly according to posts I have read. There are no diesel DJs in NA that's why help regarding the engine are few and far between. The diesel engine for the EU DJ is made by VW only through 2010. From 2011 on it is made by Fiat. Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted December 22, 2014 Report Share Posted December 22, 2014 its hard to help some people isnt it journey-sext, LOL I really don't know what to say 2late....did he miss or dismiss my post?? I'm getting no love from MrNevermind, Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted January 10, 2015 Report Share Posted January 10, 2015 (edited) The OP probably gave up but I will post this for anyone else who has this issue. P2002 TSB for 2009 Journeys P2002 Service Bulletin.pdf Edited January 10, 2015 by Journey_SeXT Quote Link to comment Share on other sites More sharing options...
cplmadison Posted November 10, 2015 Report Share Posted November 10, 2015 im very late replying to you but I have the solution to this fault. This happened with my 2.0 diesel and you code was permanent and couldnt be cleared even with the Bosch hand held. What you need to do is this: Unplug the MAF Sensor (its the one behind the air filter box on the right hand side of the engine) Now magically there will be no limp mode, drive the car for 10-15 minutes at 60 MPH Now turn off the engine and turn back on to the ACC position, plug in your magical fault code reader, the code will now clear Plug back in the MAF sensor Now you will be out of limp mode and the fault will be gone. Too late for the OP but might help some others who find this through google Lobitz68 1 Quote Link to comment Share on other sites More sharing options...
Thim60 Posted November 25, 2015 Report Share Posted November 25, 2015 It worked for me!!!! Thanks very much!! Shall I change oil, air filter or anything needs to be done now? im very late replying to you but I have the solution to this fault. This happened with my 2.0 diesel and you code was permanent and couldnt be cleared even with the Bosch hand held. What you need to do is this: Unplug the MAF Sensor (its the one behind the air filter box on the right hand side of the engine) Now magically there will be no limp mode, drive the car for 10-15 minutes at 60 MPH Now turn off the engine and turn back on to the ACC position, plug in your magical fault code reader, the code will now clear Plug back in the MAF sensor Now you will be out of limp mode and the fault will be gone. Too late for the OP but might help some others who find this through google Quote Link to comment Share on other sites More sharing options...
