Sparkyssxt Posted December 22, 2014 Report Share Posted December 22, 2014 OK. So I purchased a new mirror to replace my destroyed driver side. Had a few issues and had to swap parts, mainly the painted panel as well as the plastic trim piece at the door. (painted piece was black, my DJ is white, trim piece was broken at the leading edge) So I disassemble the connector, taking pictures as well as matching it to the old part, pull apart the swivel assembly(pita but if anyone needs to know how, let me know and I'll make a write up) swap all of my parts, modify studs where needed for proper fit... Anyways, get the thing all assembled and on the door. And my directions are all rotated CCW. Up moves right, right goes down, down goes left, and left goes up... But the right mirror operates as normal. Does anyone know of the wiring schematic(ie which color is common as well as which color controls which direction) So I can fix this thing? It's not too big of an issue, just frustrating when trying to adjust the mirror on the fly dhh3 1 Link to comment Share on other sites More sharing options...
Sparkyssxt Posted December 23, 2014 Author Report Share Posted December 23, 2014 Anybody have any ideas?? Link to comment Share on other sites More sharing options...
dhh3 Posted December 24, 2014 Report Share Posted December 24, 2014 Try moving the wires CCW, one at a time in the connector. Link to comment Share on other sites More sharing options...
bigtsr Posted December 24, 2014 Report Share Posted December 24, 2014 (edited) Mirror wiring drivers door. Let me know if this helps. Edited December 24, 2014 by bigtsr 2late4u and OhareFred 1 1 Link to comment Share on other sites More sharing options...
bigtsr Posted December 24, 2014 Report Share Posted December 24, 2014 https://techauthorityonlinedemo.extra.chrysler.com/service/repair/wiring/view/classic.htm This is where to find all the wiring diagrams. 2late4u 1 Link to comment Share on other sites More sharing options...
Sparkyssxt Posted January 18, 2015 Author Report Share Posted January 18, 2015 Sorry it took so long to get back to this guy's, I had three wires one black one green and one purple. The purple was common so I switched the black and the green. Worked like a charm. Thanks to bigstr. You were a lot of help Link to comment Share on other sites More sharing options...
bigtsr Posted January 18, 2015 Report Share Posted January 18, 2015 You're welcome - that's why we are here. Thanks for posting back. rolly 1 Link to comment Share on other sites More sharing options...
Scotty in NZ Posted September 21, 2017 Report Share Posted September 21, 2017 On 12/22/2014 at 6:12 PM, Sparkyssxt said: OK. So I purchased a new mirror to replace my destroyed driver side. Had a few issues and had to swap parts, mainly the painted panel as well as the plastic trim piece at the door. (painted piece was black, my DJ is white, trim piece was broken at the leading edge) So I disassemble the connector, taking pictures as well as matching it to the old part, pull apart the swivel assembly(pita but if anyone needs to know how, let me know and I'll make a write up) swap all of my parts, modify studs where needed for proper fit... Hi Sparky, I have the same issue. Original mirror has silver body, so I want to swap it to the new mirror. Can you explain how you did it? Link to comment Share on other sites More sharing options...
jkeaton Posted September 21, 2017 Report Share Posted September 21, 2017 3 hours ago, Scotty in NZ said: Hi Sparky, I have the same issue. Original mirror has silver body, so I want to swap it to the new mirror. Can you explain how you did it? This thread is from 3 years ago. Sparky is no longer on here. Link to comment Share on other sites More sharing options...
