Journey SXT Turn Signal
My Journey SXT Rear left turn signal does not work.
I have confirmed that the bulb filament is serviceable as is the filament housing.
I have also confirmed that there is no power at the filament housing connections.
So, my question is:
Could it be the blinker sender unit? If so where is it located.
I am unable to identify any fuses applicable to the turn signal circuit.
All suggestions welcome.
Rgds
The blinker is an integral part of the dash circuit board.
I have seen this problem before and if I recall correctly
the cause in that case proved out to be a broken wire
in the rear hatch wiring loom.
Break is likely caused by opening/closing the hatch
over a period of time.
You could as a first effort disconnect the DJ battery at
the negative jumper location for 10-15 minutes to see
the TIPM when rebooted will clear the problem.
