Milous Posted January 19, 2015 Report Share Posted January 19, 2015 Any 2011-2014 3.6L owners having idler pulley noise during cold startup? If so, a TSB was issued earlier this month... TSB NUMBER: 07-002-15 GROUP: Cooling DATE: January 07, 2015 SUBJECT: Idler Pulley Noise During Cold Start OVERVIEW: This bulletin involves replacing the idler pulley. NOTE: This bulletin applies to vehicles built on or before September 01, 2014 equipped with 3.2L V6 24V VVT Engine (sales code EHB) or 3.6L V6 24V VVT Engine (sales code ERB) SYMPTOM/CONDITION: The customer may describe a loud high frequency noise that happens within 20 seconds of engine startup and lasts about 90 seconds intermittently during a cold engine start, approximately 0 degrees C (32 degrees F) and below. PARTS REQUIRED: p/n 05281301AA Idler Pulley Eric Evans and dhh3 2 Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted January 19, 2015 Report Share Posted January 19, 2015 Here is the PDF file: idler pulley noise.pdf Potlicquor and dhh3 2 Quote Link to comment Share on other sites More sharing options...
probak118 Posted January 19, 2015 Report Share Posted January 19, 2015 Never thought that high pitched whinning noise sounded / was normal at startup in cold weather. Potlicquor 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted January 19, 2015 Report Share Posted January 19, 2015 I did not know that the 3.2 was available on the DJ; only the 3.6 Quote Link to comment Share on other sites More sharing options...
bramfrank Posted January 19, 2015 Report Share Posted January 19, 2015 It isn't in the US/Canada market, but is obviously available in others. Quote Link to comment Share on other sites More sharing options...
larryl Posted January 19, 2015 Report Share Posted January 19, 2015 I will be taking mine in Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 19, 2015 Report Share Posted January 19, 2015 I will be taking mine in post what they tell you Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted January 19, 2015 Report Share Posted January 19, 2015 (edited) Would the idler pulley be part of the powertrain warranty? I do also have the extended warranty. I would like to get this done but I am not paying out of pocket for it. Edited January 19, 2015 by Journey_SeXT silenze and Potlicquor 2 Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 19, 2015 Report Share Posted January 19, 2015 i don't think that is considered part of the power train warranty , but wouldnt hurt to check... Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCACares Posted January 20, 2015 Official Dodge Support Report Share Posted January 20, 2015 Would the idler pulley be part of the powertrain warranty? I do also have the extended warranty. I would like to get this done but I am not paying out of pocket for it. Journey_SeXT, Check with your local dealer, are you hearing the noise as well? Potlicquor 1 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted January 20, 2015 Report Share Posted January 20, 2015 Would the idler pulley be part of the powertrain warranty? I do also have the extended warranty. I would like to get this done but I am not paying out of pocket for it. If not, It should be a relatively easy repair to do yourself... Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted January 20, 2015 Report Share Posted January 20, 2015 Yup, already looking at the Chilton how to's. Quote Link to comment Share on other sites More sharing options...
larryl Posted January 20, 2015 Report Share Posted January 20, 2015 They are ordering me a new one they knew nothing about the TSB until I showed them. Quote Link to comment Share on other sites More sharing options...
B4ZINGA Posted January 20, 2015 Report Share Posted January 20, 2015 Incidentally I notice some odd sounds yesterday while the hood was open and the cold engine was running. Seemed to last a lot longer than I'm used to, a few minutes. Wasn't high pitched though, it sounded more like a louder lifter tap. I figured it sounded louder simply because the hood and hood insulator were upright, and not blocking the sound coming from the engine bay. Potlicquor 1 Quote Link to comment Share on other sites More sharing options...
probak118 Posted April 1, 2015 Report Share Posted April 1, 2015 Took DJ in yesterday for a couple items prior to 3 year warranty expire in April. Dealer replaced the tension idler pulley (lots in stock - common problem I guess). I just printed the bulletin posted above. Also, ordered a new fuel pump to address the fuel indicator never going to FULL mark, another TSB issue. Made note of the hard shift / clunk issue but that is under the 5 year warranty. Fortunately, unfortunately the replaced brake pads / rotors still good (LOL)., no replacements. Potlicquor 1 Quote Link to comment Share on other sites More sharing options...
Journeyman425 Posted April 4, 2015 Report Share Posted April 4, 2015 I did not know that the 3.2 was available on the DJ; only the 3.6 It is not - the 3.2 is a Cherokee option, but the pulley is the same on both engines. Potlicquor 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted April 4, 2015 Report Share Posted April 4, 2015 I printed out the TSB. I'll take it in to my dealer. I have not started mine for over a week. I was in the Hospital, and can not drive for another 5 days. So, I went out and started it. and it makes a sound like the power steering pump is going bad! It is definitely a rotational noise. Potlicquor and dj cowboy 2 Quote Link to comment Share on other sites More sharing options...
Journeyman425 Posted April 4, 2015 Report Share Posted April 4, 2015 (edited) The 3.6 has an inherent moaning-type sound upon cold start. Mine is particularly loud. My experience has been that the sound is louder in transverse applications like the Journey and the minivans. The Grand Cherokee, Durango and 300/Charger have a longitudinal engine orientation, and for some reason the moan is not as loud in those cars. It is not the same sound as the idler pulley in the TSB. That is a high-pitched screech or whistle-type sound which usually only lasts a few seconds; maybe more in extreme cold. Also, in extreme cold startups, the power steering pump does make a short-duration sound, similar to a low-fluid condition. The manual states that this sound is normal due to the high viscosity of the fluid at low temps. The moaning sound that I describe lasts a couple of minutes, then it is gone once the engine begins to warm up. I have been monitoring STAR cases and TSB's to identify the source but none have surfaced yet. Apparently it is not a mechanical issue since everything still works perfectly on my engine with 34,000 miles now. It has not gotten any worse, either. Edited April 14, 2015 by Journeyman425 Potlicquor, dhh3 and Journey_SeXT 3 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted April 13, 2015 Report Share Posted April 13, 2015 Took the TSB to my Dealer. We will wait until the weather gets cold again. So far, I have not recalled hearing it. Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted April 14, 2015 Report Share Posted April 14, 2015 (edited) Lol, but only when she's cold! Edited March 3, 2016 by jkeaton dhh3 1 Quote Link to comment Share on other sites More sharing options...
bigtsr Posted April 14, 2015 Report Share Posted April 14, 2015 Lol, but only when she's cold! Usually starts after the first kid comes along. But could be similar to the "defrost button" , you have to keep pushing it to make go! rolly, onecrazyfoo4u and dhh3 3 Quote Link to comment Share on other sites More sharing options...
Mysty2 Posted April 24, 2015 Report Share Posted April 24, 2015 Took my DJ in yesterday for radio problem and also took the TSB so they can replace the pulley and they told me that they have to wait for colder weather to replicate the problem. I could hear that high pitch noise when it was very cold, but I thought its was the alternator until I saw the TSB. Now I have to wait until next winter for them to look at it. What a pain!!! dhh3 1 Quote Link to comment Share on other sites More sharing options...
Journeyman425 Posted April 25, 2015 Report Share Posted April 25, 2015 Took my DJ in yesterday for radio problem and also took the TSB so they can replace the pulley and they told me that they have to wait for colder weather to replicate the problem. I could hear that high pitch noise when it was very cold, but I thought its was the alternator until I saw the TSB. Now I have to wait until next winter for them to look at it. What a pain!!! So unnecessary on their part. It's a known issue and they will get paid by the factory to replace the part. as long as you're within the provisions of the basic warranty. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Mysty2 Posted April 29, 2015 Report Share Posted April 29, 2015 I know it is unnecessary, they will have to change it anyway. I will have to leave the car probably overnight for them to reproduce the noise. It would have been more pleasant for the technician to work on it now because the part would not be as cold. dhh3 1 Quote Link to comment Share on other sites More sharing options...
silenze Posted April 29, 2015 Report Share Posted April 29, 2015 It only happens below freezing. But when its really cold she screams bloody murder. I hope its not damaging anything dhh3 1 Quote Link to comment Share on other sites More sharing options...
