Sherrie Danielle Posted February 1, 2015 Report Share Posted February 1, 2015 My 2010 Journey SXT started making a loud clicking sound behind the glove box when the A/C or heat was turned on, it would do this for maybe 10-20 seconds then stop. My husband replaced the HVAC actuator part #604-029. The noise stopped with this fix but it's back, 2 weeks later and louder than before! They had this same problem with Rams of the same year and had a recall. I've seen so many people having the problem with the Journey as well, I wish they'd do a recall. Anyways, any ideas as to why it was fine for 2 weeks and started doing it again? Thanks! Quote Link to comment Share on other sites More sharing options...
dhh3 Posted February 1, 2015 Report Share Posted February 1, 2015 Welcome to the forum. There is a small fuse box above and behind the glove box. It could be a relay clicking. Quote Link to comment Share on other sites More sharing options...
bigtsr Posted February 1, 2015 Report Share Posted February 1, 2015 Have you pulled out the cabin filter to check for debris? It is located behind the glove box. Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted February 1, 2015 Report Share Posted February 1, 2015 (edited) That part# is a Dorman aftermarket part which I am guessing is probably faulty. I would invest in the OEM which is a pretty cheap replacement part found here: http://moparonlineparts.com/repair-parts.php?cPath=23_45_290 I am assuming that you have a single zone system. Instructions are here: Single Zone/Dual Zone Left Side WARNING Disable the airbag system before attempting any steering wheel, steering column, or instrument panel component diagnosis or service. Disconnect and isolate the negative battery (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to take the proper precautions may result in accidental airbag deployment and possible serious or fatal injury. NOTE The single zone heating-A/C system is equipped with a single blend door actuator. The dual zone system has two blend door actuators, one for the driver side blend-air door and one for the passenger side blend-air door. Disconnect and isolate the negative battery cable. Disconnect the wire harness connector (1) from the blend door actuator (2) located on the left side of the HVAC air distribution housing (3). Remove the two screws (4) that secure the blend door actuator to the air distribution housing and remove the actuator. Front single zone/dual zone left side blend door actuator To install: Position the blend door actuator (2) onto the left side of the HVAC air distribution housing (3). If necessary, rotate the actuator slightly to align the splines on the actuator output shaft with those in the blend air door linkage. Install the two screws (4) that secure the blend door actuator to the air distribution housing. Tighten the screws to 17 inch lbs. (2 Nm). Connect the wire harness connector (1) to the blend door actuator. Edited February 1, 2015 by Journey_SeXT Quote Link to comment Share on other sites More sharing options...
how111now Posted September 11, 2017 Report Share Posted September 11, 2017 I have the 2 zone unit..where is the second door actuator? any diagrams for that? thanks Quote Link to comment Share on other sites More sharing options...
