Eric Evans Posted February 12, 2015 Report Share Posted February 12, 2015 Anyone had experienceof having a clunk sound when gas pedal is pressed. During my drivng when i release my foot on the gas and press back i hear a clunk sound. but when i gently press it there is no clunk. other than that egine is running well. i have DJ 2014 Limited 3.6 please anyone throw back infos. R4V3N 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 12, 2015 Report Share Posted February 12, 2015 Clunks are normal, unfortunately. If you are very concerned, a visit to the dealer is appropriate. Make sure you make them go for a ride with you so you can actually show them the issue. DodgeCACares and Eric Evans 2 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted February 12, 2015 Report Share Posted February 12, 2015 (edited) More info would be helpful... Does it always happen, only when the vehicle isn't warmed up, during shift, etc.?? Can you provide better detail of what exactly i happening? Edited February 12, 2015 by Lobitz68 Eric Evans 1 Quote Link to comment Share on other sites More sharing options...
OhareFred Posted February 12, 2015 Report Share Posted February 12, 2015 Could it be a motor mount? Eric Evans 1 Quote Link to comment Share on other sites More sharing options...
larryl Posted February 12, 2015 Report Share Posted February 12, 2015 Are your lug nuts tight? jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted February 12, 2015 Report Share Posted February 12, 2015 On 2/12/2015 at 2:23 PM, OhareFred said: Could it be a motor mount? On 2/12/2015 at 4:26 PM, larryl said: Are your lug nuts tight? Kind of why I asked for more info... Could be so many simple and cheap fixes. We really need more info. Quote Link to comment Share on other sites More sharing options...
Eric Evans Posted February 15, 2015 Author Report Share Posted February 15, 2015 (edited) Thanks for all comments and advise.... However...The clunk sound came from the front area or engine area....while cruising even slow when a release my foot on the gas pedal and press back I heard one clunk sound , evrytime I do this I hear it. but if I gently press it there is no clunk sound. THanks Eric Edited February 15, 2015 by Eric Evans Quote Link to comment Share on other sites More sharing options...
OhareFred Posted February 15, 2015 Report Share Posted February 15, 2015 Kinda sounds like a motor or trans mount. Hard acceleration will make the motor "twist" and make the clunk. Remember these engines are sideways so there is a front mount. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 15, 2015 Report Share Posted February 15, 2015 On 2/12/2015 at 4:26 PM, larryl said: Are your lug nuts tight? My wife asks me that a lot.... OhareFred 1 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted February 19, 2015 Report Share Posted February 19, 2015 On 2/15/2015 at 2:42 AM, OhareFred said: Kinda sounds like a motor or trans mount. Hard acceleration will make the motor "twist" and make the clunk. Remember these engines are sideways so there is a front mount. I agree... Should be pretty apparent to ANY mechanic. You should be able to tell by yourself as well. Have someone rev the engine while you look in the engine bay. It should not move much if at all. If the mount is bad it will be obvious. Quote Link to comment Share on other sites More sharing options...
Eric Evans Posted February 24, 2015 Author Report Share Posted February 24, 2015 hello Guys, Just pick up the DJ after reporting the clunk when acceleration. THis is a what the dealre mechanic found out.... BOTH FRONT AXLE NEED RETORQUE. CLUNK NOISE IS GONE. dhh3 1 Quote Link to comment Share on other sites More sharing options...
larryl Posted February 24, 2015 Report Share Posted February 24, 2015 Mine had to have the same repair at 1500 miles forgot about that Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCACares Posted February 24, 2015 Official Dodge Support Report Share Posted February 24, 2015 On 2/24/2015 at 12:14 AM, Eric Evans said: hello Guys, Just pick up the DJ after reporting the clunk when acceleration. THis is a what the dealre mechanic found out.... BOTH FRONT AXLE NEED RETORQUE. CLUNK NOISE IS GONE. Eric Evans, Happy to hear the noise issue was sorted out. Did your dealer mention the cause of the component going out of torque spec.? Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted February 24, 2015 Report Share Posted February 24, 2015 Does this front axle retorqueing apply to both FWD and AWD DJ's? Anytime I start accelorating I get that slight clunk (more of a knock sound). Happens just once each time I drive it. I thought it was something electrical... Quote Link to comment Share on other sites More sharing options...
apellefigliodapollo Posted February 24, 2015 Report Share Posted February 24, 2015 On 2/24/2015 at 12:14 AM, Eric Evans said: hello Guys, Just pick up the DJ after reporting the clunk when acceleration. THis is a what the dealre mechanic found out.... BOTH FRONT AXLE NEED RETORQUE. CLUNK NOISE IS GONE. had the same problem (and solution) on my freemont Quote Link to comment Share on other sites More sharing options...
larryl Posted February 25, 2015 Report Share Posted February 25, 2015 They told me they were not properly torqued from the factory Quote Link to comment Share on other sites More sharing options...
dhh3 Posted February 25, 2015 Report Share Posted February 25, 2015 Thanks for posting the results. Quote Link to comment Share on other sites More sharing options...
Appalachian Journey Posted February 25, 2015 Report Share Posted February 25, 2015 (edited) Was it the spindle nuts or the intermediate shaft bolts that needed re-torqued? Edited February 25, 2015 by Appalachian Journey Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted February 25, 2015 Report Share Posted February 25, 2015 Does this re-torqueing apply to AWD or FWD vehicles or both? Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCACares Posted February 25, 2015 Official Dodge Support Report Share Posted February 25, 2015 On 2/25/2015 at 12:45 AM, larryl said: They told me they were not properly torqued from the factory larryl, Thanks for the info.! Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted February 25, 2015 Official Dodge Support Report Share Posted February 25, 2015 On 2/24/2015 at 5:44 PM, onecrazyfoo4u said: Does this front axle retorqueing apply to both FWD and AWD DJ's? Anytime I start accelorating I get that slight clunk (more of a knock sound). Happens just once each time I drive it. I thought it was something electrical... The issue is vehicle specific and doesn't apply to all DJ's, either AWD or FWD, so I recommend taking your vehicle to a dealership to be formally diagnosed. It could turn out to be a similar issue, but it also could be something completely separate. dhh3 1 Quote Link to comment Share on other sites More sharing options...
mysbay Posted May 14, 2015 Report Share Posted May 14, 2015 I bought Journey this March and I have similar problem. The technician says its ABS kicking in and the sound is normal. I gave this solution to him but they say its not the AXle problem but normal to all Journeys as the ABS is kicked in. Not happy!!! dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 14, 2015 Report Share Posted May 14, 2015 On 5/14/2015 at 4:00 AM, mysbay said: I bought Journey this March and I have similar problem. The technician says its ABS kicking in and the sound is normal. I gave this solution to him but they say its not the AXle problem but normal to all Journeys as the ABS is kicked in. Not happy!!! Try another dealer. Take them on a test drive with you and show them. Force the issue. ABS does not kick in unless there is wheel slippage or skidding detected. dhh3 1 Quote Link to comment Share on other sites More sharing options...
bigtsr Posted May 14, 2015 Report Share Posted May 14, 2015 ABS only makes noise when you apply brakes in skid conditions. Find a competent dealer. dhh3 1 Quote Link to comment Share on other sites More sharing options...
redtomatoman Posted May 15, 2015 Report Share Posted May 15, 2015 Mine does this. Feels and sounds like a transmission clunk in my DJ. Resuming the cruise control will cause it or sometimes reapplying the accelerator after a coast will cause it. Are we talking about the same thing here? Should I have my front axles checked? I have always assumed it was a tranny noise. Re-torqued implies that axles were still tight but a clunk in the axle says to me that something came loose. If so, I'd say it was a re-tightening or securing of something related to the axle. That's mildly frightening. I think that checking the axles is part of the routine dealership inspection. Is it not? Peace. dhh3 1 Quote Link to comment Share on other sites More sharing options...
