Lobitz68 Posted May 15, 2015 Report Share Posted May 15, 2015 On 5/15/2015 at 3:11 AM, redtomatoman said: Mine does this. Feels and sounds like a transmission clunk in my DJ. Resuming the cruise control will cause it or sometimes reapplying the accelerator after a coast will cause it. Are we talking about the same thing here? Should I have my front axles checked? I have always assumed it was a tranny noise. Re-torqued implies that axles were still tight but a clunk in the axle says to me that something came loose. If so, I'd say it was a re-tightening or securing of something related to the axle. That's mildly frightening. I think that checking the axles is part of the routine dealership inspection. Is it not? Peace. mine does this if coasting in a low gear and hitting the throttle... 99% sure it is the transmission... Never does it at any other time. dhh3 1 Quote Link to comment Share on other sites More sharing options...
redtomatoman Posted May 16, 2015 Report Share Posted May 16, 2015 On 5/15/2015 at 4:18 PM, Lobitz68 said: mine does this if coasting in a low gear and hitting the throttle... 99% sure it is the transmission... Never does it at any other time. Check resuming cruise control after hitting cancel and coasting. Mine sounds like a transmission clunk. I think we are experiencing the same behavior. I'd be curious to know what was actually "re-torqued". Peace. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted May 18, 2015 Report Share Posted May 18, 2015 (edited) On 5/16/2015 at 3:33 AM, redtomatoman said: Check resuming cruise control after hitting cancel and coasting. Mine sounds like a transmission clunk. I think we are experiencing the same behavior. I'd be curious to know what was actually "re-torqued". Peace. Use that function all the time... doesn't happen then either. It does accelerate like it is possessed sometimes though. Puts my ass in the seat like I'm racing, ha! Edited May 18, 2015 by Lobitz68 dhh3 1 Quote Link to comment Share on other sites More sharing options...
redtomatoman Posted May 19, 2015 Report Share Posted May 19, 2015 On 5/18/2015 at 2:23 PM, Lobitz68 said: Use that function all the time... doesn't happen then either. Huh. OK. Happens with mine. I still think its tranny. Maybe different variations of the same behavior. Or maybe my axle is about to come off. . . ;-) Peace. dhh3 1 Quote Link to comment Share on other sites More sharing options...
casey sohc Posted November 9, 2015 Report Share Posted November 9, 2015 yup. mine was fixed...i had a noise with acceleration and decceleration it turned out to be half of the front subframe bolts were loose by at least 2 or 3 turns...the car was fairly new when this happened... dhh3 1 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted November 9, 2015 Report Share Posted November 9, 2015 On 11/9/2015 at 5:12 PM, casey sohc said: yup. mine was fixed...i had a noise with acceleration and decceleration it turned out to be half of the front subframe bolts were loose by at least 2 or 3 turns...the car was fairly new when this happened... Interesting... I suppose I should take mine in. dhh3 1 Quote Link to comment Share on other sites More sharing options...
casey sohc Posted November 9, 2015 Report Share Posted November 9, 2015 (edited) On 11/9/2015 at 9:08 PM, Lobitz68 said: Interesting... I suppose I should take mine in. i found that out myself...our local dealers 3 to choose from cant find thier butts with both hands,and if you cant plug the scanner in they cant fix it...but yes bring it in and check especally if the vin number starts with a 3 that is made in mexico the out of province deaker that i go to are old school and have seen a few mexican ones loose...im not sure if any are made in canada or the states anymore. Edited November 10, 2015 by casey sohc Quote Link to comment Share on other sites More sharing options...
bramfrank Posted November 10, 2015 Report Share Posted November 10, 2015 They only assemble them in Mexico. casey sohc and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
