  On 2/25/2015 at 3:24 PM, dhh3 said:
Just for clarification on the three power port covers: the ones with the key indicate they only work with the key in the ignition: engine running, but they might work on ACC. The one in the console has a battery. It is on all the time for charging your phone out of sight, or whatever.
No one has still answered my question: is the starter button wired to the starter, or does it just send a signal? Just curious.
Your vehicle may be different than mine, but I have FOUR outlets - (Instrument Panel; Inside the console; on the rear of the console; and one more at the rear of the vehicle on the left side) only one is powered full time and that is the one on the back of the console, as indicated . . . . yes, the switched units work in accessory mode and are subject to the delay off setting.
  On 2/25/2015 at 4:20 PM, Cliff Sadgrove said:
It makes me wonder why they show they key symbol on the two outlet covers rather than the engine symbol to show power is only available when the engine is running?
Now you know . . . . it is because the engine does not need to be running for the outlet to be powered.
  On 2/25/2015 at 8:53 PM, Cliff Sadgrove said:
The two with the key rather than the engine symbol do require the engine to be running for them to be powered.
No they don't. Just push the ignition to acc or on (with no engine running). They'll have power in those two settings as well. We do it all the time!
