Camper Posted February 22, 2015 Report Share Posted February 22, 2015 On my 2012 journey, MIL just came on, run OBD-II scan tool and what I get:""""" 2/21/2015 12:45:52 Dodge Journey 2012 Error#P0420 Catalyst System Efficiency Below Threshold (Bank 1) Freeze Frame for DTC P0420 Fuel System Status Bank One Closed Loop Fuel System Status Bank Two Closed Loop Calculated Load 52 % Coolant Temperature 92 C Short Term Fuel Trim Bank One -2.34 % Long Term Fuel Trim Bank One 2.34 % Short Term Fuel Trim Bank Two -2.34 % Long Term Fuel Trim Bank Two 1.56 % Intake Manifold Absolute Pressure 71.0 kPaA Engine RPM 1278 r/min Vehicle Speed 40 km/h Ignition Timing Advance for #1 29.5 deg Intake Air Temperature 13 C Absolute Throttle Position 18 % Absolute Throttle Position E 14 % Commanded Throttle Actuator Control 8 % """" Here is information for Oxygen sensors output:""" Does any body run on this issue? Does it mean I have to replace Catalyst Converter or just Oxygen Sensors? What is warranty for Catalyst converter on Dodge Journey? Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 22, 2015 Report Share Posted February 22, 2015 well you should still be in warranty and i believe most catalytic converters are covered for at least 100k so take it back to the dealership...let us know Quote Link to comment Share on other sites More sharing options...
Camper Posted February 22, 2015 Author Report Share Posted February 22, 2015 I do have 111 567 km. on my journey. So, I am not sure if it will covered under warranty. How long is warranty for Catalytic Converter? Somebody told me is 160000 km,is this truth? Quote Link to comment Share on other sites More sharing options...
Camper Posted February 22, 2015 Author Report Share Posted February 22, 2015 Booked appointment with dealer on Feb.27. Let you know, with resolution. Quote Link to comment Share on other sites More sharing options...
2late4u Posted February 22, 2015 Report Share Posted February 22, 2015 (edited) all par says.. on vehicles built after 1995 are warranted for eight years or 80,000 miles.in the U.S. couldnt find anything for canada...check your books that came with your car there should be a pamplet just about the catalytic converter and the related parts and how long the coverage is...that can be a hard code to get rid of it can be alot of different things causing it. google the code # and read up on it. Edited February 22, 2015 by 2late4u Quote Link to comment Share on other sites More sharing options...
Camper Posted February 25, 2015 Author Report Share Posted February 25, 2015 Went to dealer to day, dealer replaced right catalytic converter. Under Federal Law in Canada, catalytic converter covered under warranty for 10 years. Quote Link to comment Share on other sites More sharing options...
