Trouble Code - P0420 Catalyst System Efficiency Below Threshold (Bank 1)
Camper
On my 2012 journey, MIL just came on, run OBD-II scan tool and what I get:"""""
2/21/2015 12:45:52
Dodge Journey 2012
Error#P0420 Catalyst System Efficiency Below Threshold (Bank 1)
Freeze Frame for DTC P0420
Fuel System Status Bank One Closed Loop
Fuel System Status Bank Two Closed Loop
Calculated Load 52 %
Coolant Temperature 92 C
Short Term Fuel Trim Bank One -2.34 %
Long Term Fuel Trim Bank One 2.34 %
Short Term Fuel Trim Bank Two -2.34 %
Long Term Fuel Trim Bank Two 1.56 %
Intake Manifold Absolute Pressure 71.0 kPaA
Engine RPM 1278 r/min
Vehicle Speed 40 km/h
Ignition Timing Advance for #1 29.5 deg
Intake Air Temperature 13 C
Absolute Throttle Position 18 %
Absolute Throttle Position E 14 %
Commanded Throttle Actuator Control 8 % """"
Here is information for Oxygen sensors output:"""
Does any body run on this issue?
Does it mean I have to replace Catalyst Converter or just Oxygen Sensors?
What is warranty for Catalyst converter on Dodge Journey?
post-4778-0-48917200-1424620651_thumb.pn
all par says.. on vehicles built after 1995 are warranted for eight years or 80,000 miles.in the U.S. couldnt find anything for canada...check your books that came with your car there should be a pamplet just about the catalytic converter and the related parts and how long the coverage is...that can be a hard code to get rid of it can be alot of different things causing it. google the code # and read up on it.
Edited by 2late4u
