dominic58 Posted February 26, 2015 Report Share Posted February 26, 2015 (edited) My right side mirror doesnt work but the locks and window still function. i had to replace the mirror today due to a minor accident hoping that would have solved the problem. is there a way to check the door module? thanks Dom Edited February 26, 2015 by dominic58 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted February 27, 2015 Report Share Posted February 27, 2015 (edited) You can pull the switch straight up from the arm rest. It is held in place with metal friction clips. Use a panel removal tool so you don't mark it. Then you can make sure everything is plugged in tight. Edited February 27, 2015 by dhh3 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 27, 2015 Report Share Posted February 27, 2015 So it's a new mirror that does not work, correct? Is it a direct replacement? Aftermarket? Quote Link to comment Share on other sites More sharing options...
dominic58 Posted February 27, 2015 Author Report Share Posted February 27, 2015 the original mirror did not work, so when i replaced it with a after market mirror from kool vue i was hoping that it would work but it doesnt. so its iether the door module or something in the wiring. ill check out the switch and make sure its plugged in properly. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 27, 2015 Report Share Posted February 27, 2015 Have you had the door wiring recall done? Quote Link to comment Share on other sites More sharing options...
dominic58 Posted February 27, 2015 Author Report Share Posted February 27, 2015 the only open recall i have is the win module for the ignition switch. i bought this car about a year ago and didnt notice the mirror didnt function till i went to adjust it a couple months later. Quote Link to comment Share on other sites More sharing options...
