Steven Posted April 2, 2008 Report Share Posted April 2, 2008 Does anyone know if an ipod shuffle would work in the radio unit? if i plugged it into the aux input? steve Quote Link to comment Share on other sites More sharing options...
Steven Posted April 3, 2008 Author Report Share Posted April 3, 2008 I don't know if anyone would be interested in knowing, but I tried my IPOD shuffle last night. I used the USB plug. It will charge the IPOD, but will not recognize the music. I believe the reason for this is due to the design/programming of the shuffle itself. I believe once it is connected to a USB source, it kicks into the charging and ITUNES mode. I am going to try and connect it via the AUX plug. Maybe that would work. It would be nice to use the shuffle though. Then the kids can plug their respective shuffle in to listen to their music instead of carrying CD's or download every kid's cd (not enough room). Hey, it will charge the ipod though. Also, I am trying to discourage the kids from wanting the NANO. Steve Quote Link to comment Share on other sites More sharing options...
larryl Posted April 3, 2008 Report Share Posted April 3, 2008 If you look on ebay there is a connector being sold by a dealer in NC for $40?? that is supposed to make it compatible with Ipod's it gives you the radio codes that it works with & I believe it is Mopar as you get a 1yr warranty Quote Link to comment Share on other sites More sharing options...
Hit-By-Thunder Posted April 3, 2008 Report Share Posted April 3, 2008 this is what is in the manual,... NOTE: USB devices (e.g., camera memory USB adaptors, etc.) must comply with the MSD (Mass Storage Device) standard. This USB terminal can provide power to the inserted device. The devices current limitation must be less or equal to 500mA. The transfer speed for this USB connector is approximately 2 megabytes per second. MP3 player devices cannot be controlled through the USB connector. Some player devices save music files in MP4 format, which cannot be played in this radio. Some copy protected music (e.g., downloads from the internet) cannot be played on this radio. AUX Mode The AUX connector allows you to connect the headset output of an audio device (e.g., MP3 player) to the navigation radio. The audio of the connected device will then be played through the navigation radio sound system. Connect a 3.5 mm stereo mini-jack cable as shown above (not provided with the radio) to the AUX connector on the navigation radio and to the earphone connector of your audio device. The display will switch automatically to the AUX mode, when a 3.5 mm stereo mini-jack cable has been connected. The radio screen will revert back to the last tuner mode when the cable is unplugged. To change to AUX mode while the cable is connected to the unit, press the MEDIA button until the AUX tab is highlighted on the top of the screen. Adjust the volume with the ON/OFF VOLUME knob, or with the volume of the attached device. The control of the external device (e.g., selecting playlists, play, fast forward, etc.) cannot be provided by the radio; use the device controls instead. Quote Link to comment Share on other sites More sharing options...
radon360 Posted May 19, 2008 Report Share Posted May 19, 2008 Does anyone know if an ipod shuffle would work in the radio unit? if i plugged it into the aux input? steve Check the connector inside your glove box on the left side. Does this fit into your shuffle? It's supposed to fit into the iPods so that you can leave the iPod in the glove box and run it completely through the radio. I don't know what the connector on the bottom of the shuffle looks like, but I'm quite certain that it WON'T work through the USB port on the faceplate. That's only good for mass storage devices like USB jump drives and the like. Quote Link to comment Share on other sites More sharing options...
TheStewie Posted June 14, 2008 Report Share Posted June 14, 2008 I tried hooking up a Sandisk mp3 player to the USB port. It connected but will not do anything. We transferred music to the drive via a thumb drive. The cd player works too but the discs were not being ejected. The new radio is at the dealer. I hooked up the cable in the glove box and it is a real pain the way they mounted the connector. I haven't tried a true ipod with the connector yet but will shortly. Quote Link to comment Share on other sites More sharing options...
larryl Posted June 14, 2008 Report Share Posted June 14, 2008 I tried hooking up a Sandisk mp3 player to the USB port. It connected but will not do anything. We transferred music to the drive via a thumb drive. The cd player works too but the discs were not being ejected. The new radio is at the dealer. I hooked up the cable in the glove box and it is a real pain the way they mounted the connector. I haven't tried a true ipod with the connector yet but will shortly. I have a 80gb Ipod hooked up works great Quote Link to comment Share on other sites More sharing options...
DrewDawg Posted August 28, 2008 Report Share Posted August 28, 2008 I don't know if anyone would be interested in knowing, but I tried my IPOD shuffle last night. I used the USB plug. It will charge the IPOD, but will not recognize the music. I believe the reason for this is due to the design/programming of the shuffle itself. I believe once it is connected to a USB source, it kicks into the charging and ITUNES mode. I am going to try and connect it via the AUX plug. Maybe that would work. It would be nice to use the shuffle though. Then the kids can plug their respective shuffle in to listen to their music instead of carrying CD's or download every kid's cd (not enough room). Hey, it will charge the ipod though. Also, I am trying to discourage the kids from wanting the NANO. Steve Try updating the firm ware on your ipod. I had to update it on mine in order for it to mate up with the radio. Quote Link to comment Share on other sites More sharing options...
