DIY Power Steering Flush
cplmadison
Hi
Has anyone done their own Power Steering flush? Mine needs doing pretty urgently its only done 28k miles but the fluid is pretty brown looking and I suspect its the original factory stuff which needs to come out anyway (dont want any blown hoses!)
Just curious where the return hose is and how easy it is to get to. I have to 2010 2.0 CRD SXT (europe model) I know the engine is different to the US ones but I suspect the power steering stuff is all the same (just on the correct side of the car :P )
I'll be doing an oil change anyway so will have the belly pan off, so if someone could direct me in the right direction of the return hose that would be appreciated. I have 2 litres of the Valvoline Fully sythetic atf+4 ready to go in (I assume is this enough?)
thanks
actually found this video on youtube:
seems much easier than removing the return hose ! :)
this would work but you have to do it many times to flush out the lines,better to remove the return line if possible and slowly add as it drains... good luck
any idea how much fluid it holds? I looked in the owners manual and it doesnt state the capacity for the psf
