new member firat time journey owner
gallegos07
I purchased a 2015 journey because of its cargo room, size, and economy. But I read it has a 20 gallon tank and even my owners Manuel says 20 gallons. But I put gas recently from empty and at only 3\4 of a tank it was at 10/11 gallons. Any suggestions or am I just reading it wrong.. Thanks
I always let my out of gas warning to be light on, and I read "Lo Fuel" on the DTE option of EVIC, then, I can put easyly 18 gallons (almost 70 litres). Sometimes, after driving for 20 miles, more or less, with warning light on, I put 19 gallons.
I would do this test before going to the dealer: Try to fill tank as slowly as you can. When hose stops for first time, tank is not full, that's sure. Wait for 30 seconds or 1 minute, and press hose trigger to fill again, you'll be able to put another gallon, at least. If you repeat that waiting after second stop, it's posible you get a 19 gallons fuelup (if tank was almost empty).
Same here, I've ran it down to the low fuel light many times, and was able to put 18-19 gallons in. Yet my gauge reads 7/8 full every time. I think the gauge is just wrong cause it seems like I'm using the full 21gal tank capacity (low fuel light comes on with about 2-3 gallons to go). Stupid gauge is wrong IMO.
  • Official Dodge Support
gallegos07,
Welcome to the forum!
I hope you find the information that you're looking for here, but if not I recommend taking your vehicle to the dealership so they can take a look at it. Keep us posted!
