Topher37 Posted March 17, 2015 Report Share Posted March 17, 2015 I have a 2011 dodge journey 3.6 and want to know how to change the transmission fluid. I am boggled why I can not find where the drain plug or filler is. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 17, 2015 Report Share Posted March 17, 2015 No drain or filler plug. Trans service is supposed to be a dealer only service. If you want to do it yourself, you will have to drop the pan and make sure you add the exact amount back in since there is no way to measure it with a dipstick. Quote Link to comment Share on other sites More sharing options...
Topher37 Posted March 17, 2015 Author Report Share Posted March 17, 2015 Ok, thanks for replying. Guess it's off to the dealer Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted March 17, 2015 Report Share Posted March 17, 2015 I'm in the same boat as you...just hit 83k miles and figured I'll be doing the transmission flush soon. Will probably cost $200 or so at the dealer. I hate to take it to the dealer since I do all of my own maintenance...but looks like I'll have to this time around! Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 17, 2015 Report Share Posted March 17, 2015 My guess it's more than $200. Had a minivan in the dealer about 8 years ago for a trans service. Close to $500. Quote Link to comment Share on other sites More sharing options...
2late4u Posted March 17, 2015 Report Share Posted March 17, 2015 (edited) no reason to go to the dealer if you dont want to my last fluid and filter change with my reg mech. was 125. i don't do flushes as i heard different stores so i just stick with the reg filter and fluid.. and to be honest it has been about 6 yrs ago when i had the last one done. i just called a dodge dealer and he said $199. and that was for a trans flush. so i asked about doing spark plugs and they quoted $289. for the 3.6 engine Edited March 17, 2015 by 2late4u onecrazyfoo4u 1 Quote Link to comment Share on other sites More sharing options...
bfurth Posted March 18, 2015 Report Share Posted March 18, 2015 I have a 2010 Town and Country with the same 62te transmission. I had the transmission fluid changed for $140, taxes and shop fees included (had a dealer coupon). The only "reason" you can't get the fluid level correct without going to a dealer is because the level on the dealer dipstick is based on the current temperature of the transmission. The pan needs to be dropped, there is a filter that gets replaced, and the gasket is made with RTV. If you can get the cost down to $140, it's not much more than the cost of doing it yourself (and has the added advantage of being documented, and on someone else's dime if it's been done incorrectly). OhareFred and onecrazyfoo4u 2 Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted March 18, 2015 Report Share Posted March 18, 2015 On 3/17/2015 at 11:45 PM, 2late4u said: no reason to go to the dealer if you dont want to my last fluid and filter change with my reg mech. was 125. i don't do flushes as i heard different stores so i just stick with the reg filter and fluid.. and to be honest it has been about 6 yrs ago when i had the last one done. i just called a dodge dealer and he said $199. and that was for a trans flush. so i asked about doing spark plugs and they quoted $289. for the 3.6 engine On 3/18/2015 at 2:07 AM, bfurth said: I have a 2010 Town and Country with the same 62te transmission. I had the transmission fluid changed for $140, taxes and shop fees included (had a dealer coupon). The only "reason" you can't get the fluid level correct without going to a dealer is because the level on the dealer dipstick is based on the current temperature of the transmission. The pan needs to be dropped, there is a filter that gets replaced, and the gasket is made with RTV. If you can get the cost down to $140, it's not much more than the cost of doing it yourself (and has the added advantage of being documented, and on someone else's dime if it's been done incorrectly). Great info guys, thanks! Looks like I'll avoid a full flush then (which probably costs more anyways). Just ask for a drain, filter change, and refill then? What fluid did you guys go with? Just the standard mopar transmission fluid, or did you upgrade to synthetic or anything? Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted March 18, 2015 Report Share Posted March 18, 2015 On 3/17/2015 at 11:34 PM, jkeaton said: My guess it's more than $200. Had a minivan in the dealer about 8 years ago for a trans service. Close to $500. You had to have had other work done to tally up to $500! There's no way just a trans drain or flush cost that much! Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 18, 2015 Report Share Posted March 18, 2015 On 3/18/2015 at 5:31 PM, onecrazyfoo4u said: You had to have had other work done to tally up to $500! There's no way just a trans drain or flush cost that much! You are correct. My bad. It was a 60,000 mile complete service which included trans service. My bad. Hey, it was really almost 10 years ago.....I have CRS disease! Quote Link to comment Share on other sites More sharing options...
2late4u Posted March 18, 2015 Report Share Posted March 18, 2015 id stick to the manufacture mopar fluid so they cant say you voided your powertrain warranty Quote Link to comment Share on other sites More sharing options...
bfurth Posted March 18, 2015 Report Share Posted March 18, 2015 On 3/18/2015 at 5:30 PM, onecrazyfoo4u said: Great info guys, thanks! Looks like I'll avoid a full flush then (which probably costs more anyways). Just ask for a drain, filter change, and refill then? What fluid did you guys go with? Just the standard mopar transmission fluid, or did you upgrade to synthetic or anything? Mine was done at the dealer - they used Mopar ATF+4 and a Mopar filter. ATF+4 is already a synthetic lubricant. It's also $8/quart. The total cost of parts to do a drain and filter change is about $110 (8 bottles of fluid, plus a $30 filter, plus applicable taxes). The 62te should not be "flushed," ever. Just a drain and fill with filter change. When done at the appropriate interval, you shouldn't have problems. Having the dealer do it eliminates any headaches you'd ever have, just make sure you get a good discount on them actually performing the service. For a dealer to do it, it's really about 30-40 minutes of actual work, most of which is cleaning the RTV off the mating surfaces. The only reason you "can't" do it at home is that you don't necessarily know the temperature of the transmission fluid. Though, if your EVIC tells you what the transmission temp is (as my 2015 does), then the only thing you need is the correct dip stick (which can be found for the minivan platform with the 62te, and I'd imagine the fluid level is the same, but I don't work for a dealer, so I don't know for a fact). onecrazyfoo4u 1 Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted March 18, 2015 Report Share Posted March 18, 2015 On 3/18/2015 at 7:30 PM, bfurth said: Mine was done at the dealer - they used Mopar ATF+4 and a Mopar filter. ATF+4 is already a synthetic lubricant. It's also $8/quart. The total cost of parts to do a drain and filter change is about $110 (8 bottles of fluid, plus a $30 filter, plus applicable taxes). The 62te should not be "flushed," ever. Just a drain and fill with filter change. When done at the appropriate interval, you shouldn't have problems. Having the dealer do it eliminates any headaches you'd ever have, just make sure you get a good discount on them actually performing the service. For a dealer to do it, it's really about 30-40 minutes of actual work, most of which is cleaning the RTV off the mating surfaces. The only reason you "can't" do it at home is that you don't necessarily know the temperature of the transmission fluid. Though, if your EVIC tells you what the transmission temp is (as my 2015 does), then the only thing you need is the correct dip stick (which can be found for the minivan platform with the 62te, and I'd imagine the fluid level is the same, but I don't work for a dealer, so I don't know for a fact). Good info, thanks man. I bet the dealer pays about 1/4 that price for the parts though...but at $150 it is a decent deal to get the service done. I will definitely do just the drain and refill, no flush. I don't think there is any dipstick on our DJ to check transmission fluid level. Don't the just pump in the correct amount of fluid and call it good? Quote Link to comment Share on other sites More sharing options...
bfurth Posted March 18, 2015 Report Share Posted March 18, 2015 On 3/18/2015 at 9:11 PM, onecrazyfoo4u said: Good info, thanks man. I bet the dealer pays about 1/4 that price for the parts though...but at $150 it is a decent deal to get the service done. I will definitely do just the drain and refill, no flush. I don't think there is any dipstick on our DJ to check transmission fluid level. Don't the just pump in the correct amount of fluid and call it good? The dealer has the correct tool (I don't remember the part number). The easiest thing to do is take a wire coat hangar, straighten it, and mark it for the correct level (this assumes you know what those dimensions are). This is the actual recommendation for the 2008-2012 T&C/GC in the Haynes manual. I don't know what the level is for the DJ, so I wouldn't use that as a reference without confirming the measurements first. It's the same transmission and engine, so you'd think it would be close, but you never know. Alternatively, if you can get a dealer to read the level, then you can get a test case for full and hot, and then you only need to get it to that point. Without a proper service manual, it's a lot of guess work. Transmissions are not something to guess with. Quote Link to comment Share on other sites More sharing options...
silenze Posted March 18, 2015 Report Share Posted March 18, 2015 Just measure before you do the fluid change. And mark that level on your stick as a baseline Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted March 18, 2015 Report Share Posted March 18, 2015 I'm still hoping for a Youtube how-to on this but I think I'll have it done by the dealer.....seems like a real pain to do. Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted March 18, 2015 Report Share Posted March 18, 2015 Fluid And Filter Service FLUID AND FILTER SERVICE FLUID/FILTER SERVICE (RECOMMENDED) NOTE Refer to the maintenance schedules in LUBRICATION and MAINTENANCE, or the vehicle owner's manual, for the recommended maintenance (fluid/filter change) intervals for this transaxle. NOTE Only fluids of the type labeled MOPAR® ATF+4 should be used. A filter change should be made at the time of the transmission oil change. The magnet (on the inside of the oil pan) should also be cleaned with a clean, dry cloth. NOTE If the transaxle is disassembled for any reason, the fluid and filter should be changed. Raise vehicle on a hoist. Refer to LUBRICATION and MAINTENANCE for proper procedures. Place a drain container with a large opening, under transaxle oil pan. Loosen pan bolts and tap the pan at one corner to break it loose allowing fluid to drain, then remove the oil pan. Remove nuts at the oil filter. Install a new filter and nuts, tighten to 5 N·m (40 in. lbs.). Install the fluid filter oil pan, use a bead of MOPAR® ATF RTV (MS-GF41). Clean the oil pan and magnet. Reinstall pan using new MOPAR® Silicone Adhesive sealant. Tighten oil pan bolts to 12 N·m (105 in. lbs.). Pour four Quarts of MOPAR® ATF+4 through the dipstick opening. Start engine and allow to idle for at least one minute. Then, with parking and service brakes applied, move selector lever momentarily to each position, ending in the park or neutral position. Check the transaxle fluid level and add an appropriate amount to bring the transaxle fluid level to 3 mm (1/8 in.) below the lowest mark on the dipstick. Recheck the fluid level after the transaxle has reached normal operating temperature 82° C (180°F). Refer to Fluid Level and Condition Check for the proper fluid fill Fluid Level And Condition Check FLUID LEVEL AND CONDITION CHECK FLUID LEVEL CHECK USING THE SCAN TOOL TEMP CHART Click to Enlarge Verify that the vehicle is parked on a level surface. Remove the dipstick tube cap. WARNING There is a risk of accident from vehicle moving when the engine is running. Secure vehicle to prevent it from moving. There is a risk of injury from contusions and burns if you insert your hands into the engine when it is running. Do not touch hot or rotating parts. Wear properly fitted work clothes. Actuate the service brake. Start engine and let it run at idle speed in selector lever position "P". Shift through the transmission modes several times with the vehicle stationary and the engine idling. NOTE When inserting dipstick special tool Dipstick, excess insertion force may cause the dipstick to slip past the stop on the bracket in the transmission oil pan. An approximate distance that the dipstick sould be inserted into the fill tube is 424 mm (16.69 in.). Warm up the transmission, wait at least 2 minutes and check the oil level with the engine running. Push the Oil Dipstick Dipstick into transmission fill tube until the dipstick tip contacts the oil pan and pull out again, read off oil level, repeat if necessary. NOTE The dipstick will protrude from the fill tube when installed. Check transmission oil temperature using the appropriate scan tool. The transmission Oil Dipstick Dipstick has indicator marks every 10 mm. Determine the height of the oil level on the dipstick and using the height, the Transmission Fluid Temperature (TFT) as viewed with the scan too, and the Transmission Fluid Graph, determine if the transmission oil level is correct. Add or remove oil as necessary and recheck the oil level. Once the oil level is correct, install the dipstick tube cap. FLUID CONDITION Along with fluid level, it is important to check the condition of the fluid. When the fluid smells burned, and is contaminated with metal or friction material particles, a complete transaxle recondition is probably required. Be sure to examine the fluid on the dipstick closely. If there is any doubt about its condition, drain out a sample for a double check. MOPAR® ATF+4 (Automatic Transmission Fluid) when new is red in color. The ATF is dyed red so it can be identified from other fluids used in the vehicle such as engine oil or antifreeze. The red color is not permanent and is not an indicator of fluid condition. As the vehicle is driven, the ATF will begin to look darker in color and may eventually become brown. This is normal. ATF+4 onecrazyfoo4u 1 Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted March 18, 2015 Report Share Posted March 18, 2015 Good post! Looks easy enough to do, would just need to order the special dip stick tool to check for levels. But for ease of service, I think I'll take my vehicle to the dealer; even though I hate to do it! Quote Link to comment Share on other sites More sharing options...
bfurth Posted March 18, 2015 Report Share Posted March 18, 2015 I'll do a lot of maintenance on my vehicles. The 62te drain and fill is one I don't particularly feel like doing myself. Reason 1 is the warranty coverage - it's an expensive component to have to repair, and I don't feel like dealing with questions as to whether or not it was done correctly. Reason 2 is that the hassle involved with draining that particular transmission (since there is no drain bolt), refilling it, and making sure it's done just right, is worth the extra $30 to pay someone else to do it. Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted March 18, 2015 Report Share Posted March 18, 2015 (edited) On 3/18/2015 at 11:42 PM, bfurth said: I'll do a lot of maintenance on my vehicles. The 62te drain and fill is one I don't particularly feel like doing myself. Reason 1 is the warranty coverage - it's an expensive component to have to repair, and I don't feel like dealing with questions as to whether or not it was done correctly. Reason 2 is that the hassle involved with draining that particular transmission (since there is no drain bolt), refilling it, and making sure it's done just right, is worth the extra $30 to pay someone else to do it. Your right there is no drain bolt but once you drop the pan you could install one for future use. Edited March 18, 2015 by Journey_SeXT onecrazyfoo4u 1 Quote Link to comment Share on other sites More sharing options...
bfurth Posted March 18, 2015 Report Share Posted March 18, 2015 To follow up to Journey_SeXT: The dipstick can be made at home with the following items: 1 wire hangar duct tape some marking tool (file, knife, whatever) Straighten the hangar - you need something more than 18 inches in length (so you drop it into the fill tube). Measure 424mm from one end, and mark this off (use the duct tape). Everything below that point will go into the filler tube (marked with the "Dealer Only" cap). Use the chart Journey_SeXT posted and mark your min/max levels. Journey_SeXT 1 Quote Link to comment Share on other sites More sharing options...
Never Dun Ranch Posted July 15, 2017 Report Share Posted July 15, 2017 Does anyone know if the 2010 has a transmission filler tube? Quote Link to comment Share on other sites More sharing options...
2late4u Posted July 15, 2017 Report Share Posted July 15, 2017 yes Quote Link to comment Share on other sites More sharing options...
Gmjourney75 Posted August 2, 2017 Report Share Posted August 2, 2017 My DJ is a 2012 with a 2.4 engine. It has a dip stick for the transmission so would it make it serviceable other than taking it to the dealer Quote Link to comment Share on other sites More sharing options...
larryl Posted August 2, 2017 Report Share Posted August 2, 2017 Any garage can change the filter and fluid, you can also there is no drain plug so you drop the pan change the filter also jkeaton 1 Quote Link to comment Share on other sites More sharing options...
