Tito Mon Posted April 5, 2015 Report Share Posted April 5, 2015 Hi guys,, I need help if somebody experience or problem like my DJ back door switch,, I replace the battery of my 2012 keyfob,, the driver door and passenger side door is working,, but the back door switch is not everytime I push it,, is there somebody encounter that,, thanks a lot,, dhh3 and Potlicquor 2 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted April 5, 2015 Report Share Posted April 5, 2015 How do you have it programmed? Mine is programmed so it will unlock only the driver's door with the first push. The second push unlocks the rest of the doors and the hatch. Potlicquor and Tito Mon 2 Quote Link to comment Share on other sites More sharing options...
Tito Mon Posted April 6, 2015 Author Report Share Posted April 6, 2015 I set to all door but the same,, the back door switch doesn't work,, dhh3 1 Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCACares Posted April 7, 2015 Official Dodge Support Report Share Posted April 7, 2015 Hi guys,, I need help if somebody experience or problem like my DJ back door switch,, I replace the battery of my 2012 keyfob,, the driver door and passenger side door is working,, but the back door switch is not everytime I push it,, is there somebody encounter that,, thanks a lot,, Tito Mon, Sorry to hear you're having troubles with the key fob. The switch itself may be problematic and/or worn out. At this stage, I would recommend having your dealer look at both the key fob and your vehicle to verify what the issue may be. weasey31, Tito Mon and dhh3 3 Quote Link to comment Share on other sites More sharing options...
Tito Mon Posted April 9, 2015 Author Report Share Posted April 9, 2015 I'm thinking of FUSE,, is there a fuse correspondent to the tailgate switch door? I look it in the diapraghm but I cannot find it,, as much as I want it DIY for me first,, thanks guys,, dhh3 1 Quote Link to comment Share on other sites More sharing options...
bigtsr Posted April 9, 2015 Report Share Posted April 9, 2015 I don't believe you will find an individual fuse for the switch, they don't do that. The tailgate is a dirt magnet could be part of the problem but could also be a broken wire in the cabin to hatch door loom and this been a reported failure in the past. dhh3 and Tito Mon 2 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted April 9, 2015 Report Share Posted April 9, 2015 I agree ^^ with the above post. Does everything else work on the hatch? lights, locks Quote Link to comment Share on other sites More sharing options...
Tito Mon Posted April 10, 2015 Author Report Share Posted April 10, 2015 thanks guys,, maybe i'll open it,, try to check the dirt and the wiring of the tailgate,, dhh3 1 Quote Link to comment Share on other sites More sharing options...
weasey31 Posted November 6, 2015 Report Share Posted November 6, 2015 The key fob remote could be worn out. The fobs can attract moisture if there's any cracks in the rubber push buttons or plastic casing has been broken exposing the inside. The electronic circuit board inside can get oxidized and prevent the small metal buttons from making contact when you press any function (panic, unlick, lock, start) on the remote. dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted November 6, 2015 Report Share Posted November 6, 2015 (edited) I put key fob and keys in the ruler pocket of my jeans. The fob has now been cleaned 2x in the washer with Arm and Hammer detergent and Downey softener. Still works fine! I need to stop doing this! Edited November 6, 2015 by dhh3 weasey31 1 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted November 6, 2015 Report Share Posted November 6, 2015 I put key fob and keys in the ruler pocket of my jeans. The fob has now been cleaned 2x in the washer with Arm and Hammer detergent and Downey softener. Still works fine! I need to stop doing this! At least it stays clean and smells good! dhh3 1 Quote Link to comment Share on other sites More sharing options...
weasey31 Posted November 9, 2015 Report Share Posted November 9, 2015 I put key fob and keys in the ruler pocket of my jeans. The fob has now been cleaned 2x in the washer with Arm and Hammer detergent and Downey softener. Still works fine! I need to stop doing this! Wow dhh3! Things go well for you. Both of mine are cracked and exposed. My daughter threw one of the two FOB's on the macadum this weekend and it busted into gazillion pieces. I have one left! dhh3 1 Quote Link to comment Share on other sites More sharing options...
rolly Posted November 9, 2015 Report Share Posted November 9, 2015 I put key fob and keys in the ruler pocket of my jeans. The fob has now been cleaned 2x in the washer with Arm and Hammer detergent and Downey softener. Still works fine! I need to stop doing this! Wow dhh3! Things go well for you. Both of mine are cracked and exposed. My daughter threw one of the two FOB's on the macadum this weekend and it busted into gazillion pieces. I have one left! Dave uses Downey fabric softener, so if you had run them through the washer and used Bounce it might not have busted. dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted November 10, 2015 Report Share Posted November 10, 2015 I didn't dry them; so no need for bounce. I did put them on the top of the dryer to get some heat into them! Oh, and yes, the dryer was running. Quote Link to comment Share on other sites More sharing options...
