Tito Mon Posted April 11, 2015 Report Share Posted April 11, 2015 hi guys,, i went to check my 2011 DJ,, and they said that i had a low battery sign,, if i had a chance i will replce it on my own,, the question is,, after i've done it, is there a system reset for everthing connected?is there a concern about the battery replacing on DIY? thanks guys Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted April 11, 2015 Report Share Posted April 11, 2015 REMOVAL WARNING To protect the hands from battery acid, a suitable pair of heavy duty rubber gloves should be worn when removing or servicing a battery. Safety glasses also should be worn. WARNING Remove metallic jewelry to avoid injury by accidental arcing of battery current. CAUTION The negative battery cable remote terminal (2) must be disconnected and isolated from the remote battery post (1) prior to service of the vehicle electrical systems. The negative battery cable remote terminal can be isolated by using the supplied isolation hole (3) in the terminal casing. Disconnect and isolate the negative battery cable remote terminal from the remote battery post. Remove the left front wheel and tire assembly (Refer to Tires and Wheels - Removal). NOTE Gasoline battery shown, diesel battery similar. Remove the push pins (1) and remove the left front wheelhouse splash shield (2) (Refer to Body/Exterior/SHIELD, Splash - Removal)(Refer To List 1). Loosen the nut (1) and position the battery hold down bracket out of the way (3). Loosen the pinch clamp bolts and position aside the battery cable clamps from the battery. Remove the battery (1) from the battery tray (2). Tito Mon 1 Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted April 11, 2015 Report Share Posted April 11, 2015 INSTALLATION WARNING To protect the hands from battery acid, a suitable pair of heavy duty rubber gloves should be worn when removing or servicing a battery. Safety glasses also should be worn. WARNING Remove metallic jewelry to avoid injury by accidental arcing of battery current. CAUTION The negative battery cable remote terminal (2) must be disconnected and isolated from the remote battery post (1) prior to service of the vehicle electrical systems. The negative battery cable remote terminal can be isolated by using the supplied isolation hole (3) in the terminal casing. Install the battery (1) into the battery tray (2). Install the battery terminal pinch clamps (1, 2) onto the battery posts. (Tighten to the proper torque specification). Position back the battery hold down bracket (3) and install the bracket nut (1). (Tighten to the proper specification). Install the left front wheelhouse splash shield (2) and push pins (1) (Refer to Body/Exterior/SHIELD, Splash - Installation)(Refer To List 1). Install the left front wheel and tire assembly (Refer to 22 - Tires and Wheels - Removal). Install the negative battery cable remote terminal onto the remote battery post. (Tighten to the proper specification). Quote Link to comment Share on other sites More sharing options...
bigtsr Posted April 11, 2015 Report Share Posted April 11, 2015 hi guys,, i went to check my 2011 DJ,, and they said that i had a low battery sign,, if i had a chance i will replce it on my own,, the question is,, after i've done it, is there a system reset for everthing connected?is there a concern about the battery replacing on DIY? thanks guys By disconnecting the battery you will be doing a system reset. You won't however loose your presets on the radio. Tito Mon 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted April 11, 2015 Report Share Posted April 11, 2015 Changing the battery on a DJ is like changing the spark plugs on my 1990 Bronco II. The left front wheel needs to be removed! Someone else can do it! LOL rolly and Tito Mon 2 Quote Link to comment Share on other sites More sharing options...
OhareFred Posted April 11, 2015 Report Share Posted April 11, 2015 Did mine on my 09 Took all of 20 mins. Not really a big deal at all Tito Mon 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted April 11, 2015 Report Share Posted April 11, 2015 (edited) did mine on my 2011 it was not to hard but remove the tire makes it a lot easier also one of the cables that connect to the battery was at a 45 degree offset and was a different size nut that i remember which was about 1.5 yrs ago . but no sweat take your time and save some money P.S. beware of sharp edges lol Edited April 11, 2015 by 2late4u Tito Mon 1 Quote Link to comment Share on other sites More sharing options...
Tito Mon Posted April 12, 2015 Author Report Share Posted April 12, 2015 Thanks guys,, its a big help for me,, its good i'm a member of these,, i'll post it when i did it,, Quote Link to comment Share on other sites More sharing options...
