Lobitz68 Posted April 21, 2015 Report Share Posted April 21, 2015 Noticed a chip in the paint where the front fender bulges out around the tire about the size of a pencil tip. Looks like it has already started to rust some. I have a fairly good idea what needs to be done, but am looking for advice anyway... How would you proceed? Quote Link to comment Share on other sites More sharing options...
bfurth Posted April 21, 2015 Report Share Posted April 21, 2015 My 2010 T&C had a spot on the inside of the driver door panel, right next to the window, that was rusting from inside the paint. I took out a Dremel with a wire wheel, removed the paint that was bubbling, and ran it until there was no visible rust left. It cleared a spot about the size of my thumbnail. I applied two coats of primer, two coats of paint, and two coats of clearcoat. Aside from the premanently marred metal, it's fine. No further rust has been noticed. It was also the inside of the door, so I wasn't as concerned about appearance. Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted April 22, 2015 Author Report Share Posted April 22, 2015 (edited) Oh... Fix it. Interesting approach. Edited August 5, 2016 by jkeaton Quote Link to comment Share on other sites More sharing options...
apellefigliodapollo Posted April 23, 2015 Report Share Posted April 23, 2015 great work the tape matches perfectly the color! 11journeybama and onecrazyfoo4u 2 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted April 23, 2015 Report Share Posted April 23, 2015 Depending how big the repair is, you have to eliminate the rust. You may have to touch it up with primer first. Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted April 23, 2015 Author Report Share Posted April 23, 2015 Not getting a whole bunch of useful advice here, so I will post what my plan is and maybe someone will have something to say about that... I plan on taping off the vehicle around the rust and sanding the area down enough to remove the rust and feather the edge to the good paint. I will then primer, paint and clearcoat the repair area. I assume I will also need to wetsand it to smooth out the repair, after which I will need to buff the repair to return the gloss... Am I missing anything? dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted April 23, 2015 Report Share Posted April 23, 2015 Sounds like a plan. Sounds good to me. I'm thinking that there is a liquid rust remover, but I could be wrong. It might affect the surrounding paint. Quote Link to comment Share on other sites More sharing options...
rolly Posted April 23, 2015 Report Share Posted April 23, 2015 (edited) You're so smart! Edited August 5, 2016 by jkeaton Quote Link to comment Share on other sites More sharing options...
