Putting Trans into Drive Gives a Loud Thunk Sometimes
Welcome to the forum. If you check further into the transmission section, you'll find that there is a lot of discussion on this particular topic. It's sometime noticeable at first start up when the transmission is cold. Many forum members have found that if you put it in neutral first a few seconds before shifting into drive it makes a difference.
Edited by rolly
  • 3 years later...
I had the same problem and was told that it was normal... I did a quick relearn of the transmission (with an expensive scanner) and no more big clunk when I shift from park to drive.
I think it had this problem since I bought the car in 2012. Having tried that before I believe the transmission would be less crappy now that I have 160K km on it...
