Michael Debnath Posted June 4, 2015 Report Share Posted June 4, 2015 Hi guys !!! My Dodge Journey (automatic) crdx is trying to wheel spin (or at least it feels like it ) when pulling off ( really shuddering ) it's getting really annoying to the point I'm thinking of changing for a different car ..... Anyone else had this ? Or know what the problem may be ?? Much appreciated 👍🏽 dhh3 1 Quote Link to comment Share on other sites More sharing options...
Michael Debnath Posted June 4, 2015 Author Report Share Posted June 4, 2015 Also a rattling noise, I believe it's coming from the front of the vehicle .... dhh3 1 Quote Link to comment Share on other sites More sharing options...
nigelwedge Posted August 17, 2015 Report Share Posted August 17, 2015 Hi, did you manage to solve this issue. I seem to have the exact same problem on mine. dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted August 17, 2015 Report Share Posted August 17, 2015 What engine? I can burn rubber from a standstill with my V6 - depends on how much gas I give it. I have never floored it because the torque steer is horrendous. When they decided to put the Pentastar in the DJ, the engineers should have figured out how to do it with equal length half shafts. JoeyVegas 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted August 17, 2015 Report Share Posted August 17, 2015 Maybe try lightening up on the gas when you accelerate from a stop if the front wheels are spinning. dhh3 1 Quote Link to comment Share on other sites More sharing options...
bigtsr Posted August 17, 2015 Report Share Posted August 17, 2015 I think these posts are using the diesel and they do develop shuddering problem with acceleration if the EGR valve is starting to fail ,previous posts have pointed to this problem. OhareFred, dhh3 and jkeaton 3 Quote Link to comment Share on other sites More sharing options...
bramfrank Posted August 17, 2015 Report Share Posted August 17, 2015 (edited) One would think that if there's a problem the local dealer would be the first resource to be consulted. Neither poster mentioned checking with the dealer at all. Edited August 17, 2015 by bramfrank jkeaton 1 Quote Link to comment Share on other sites More sharing options...
David Gruar Posted August 22, 2015 Report Share Posted August 22, 2015 I have had this problem for a few months too. Our Journey is 2009 diesel auto. We have just lived with the problem, pulling off a bit slower seems to reduce the amount of shuddering. It seems to shudder most when pulling off on a hill. I will do some research too, if as bigtsr suggest its an EGR valve, ill get that done and give some feedback. Thanks, David dhh3 and Michael Debnath 2 Quote Link to comment Share on other sites More sharing options...
nigelwedge Posted August 29, 2015 Report Share Posted August 29, 2015 Hi, mine too is a diesel automatic. It seems worse when trying to pull off going up hill, fine going down. It seems like the wheels spin, but can't be sure. Seems more like a transmission issue, but changes gear fine once running. Michael Debnath and dhh3 2 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted August 29, 2015 Report Share Posted August 29, 2015 diesel has a lot of torque. dhh3 1 Quote Link to comment Share on other sites More sharing options...
David Gruar Posted August 31, 2015 Report Share Posted August 31, 2015 I stripped the feeding hoses to the EGR but couldnt undo all of the bolts. Too difficult to access with my big hands! I did notice there was considerable amount of gunk (coke as you call it in US and Canada?) to the inside of the EGR assembly. I managed to degrease a small portion however to do it properly will not stripped off. I didnt notice any difference, however as mentioned above I didnt actually strip it off properly. Id suggest you get your local garage to do the job. Thats what I will do. As they have the right tools i would expect they can strip, clean and replace within 2 hours. There doesnt seem to be any need to buy a new unit, just get them to clean your old unit (using brake and clutch cleaner most likely). As soon as I get mine done I will update further. David jkeaton, Michael Debnath and dhh3 3 Quote Link to comment Share on other sites More sharing options...
Michael Debnath Posted September 17, 2015 Author Report Share Posted September 17, 2015 Hi guys I'm still no further on, the local dealer is at a loss also, any of you guys get to the bottom of this annoying fault ? dhh3 1 Quote Link to comment Share on other sites More sharing options...
MagicMike Posted November 3, 2015 Report Share Posted November 3, 2015 (edited) Hi guys. Would hate to the bearer of bad news but my DJ had the same problem and also fluctuating revs as if the transmission couldn't decide whether to change gear already or not. It would happen in some gears only. Still had warranty with the trader I had bought the car from so they rectified this free of charge. I was glad I didn't have to shell out £2.6k they did for a new clutch set...mine is a 2008 SXT CRD. Edited November 3, 2015 by MagicMike dhh3 and Michael Debnath 2 Quote Link to comment Share on other sites More sharing options...
Michael Debnath Posted January 14, 2017 Author Report Share Posted January 14, 2017 On 17/08/2015 at 5:13 PM, nigelwedge said: Hi, did you manage to solve this issue. I seem to have the exact same problem on mine. Did you ever solve the problem ? Quote Link to comment Share on other sites More sharing options...
Michael Debnath Posted January 14, 2017 Author Report Share Posted January 14, 2017 On 31/08/2015 at 0:45 PM, David Gruar said: I stripped the feeding hoses to the EGR but couldnt undo all of the bolts. Too difficult to access with my big hands! I did notice there was considerable amount of gunk (coke as you call it in US and Canada?) to the inside of the EGR assembly. I managed to degrease a small portion however to do it properly will not stripped off. I didnt notice any difference, however as mentioned above I didnt actually strip it off properly. Id suggest you get your local garage to do the job. Thats what I will do. As they have the right tools i would expect they can strip, clean and replace within 2 hours. There doesnt seem to be any need to buy a new unit, just get them to clean your old unit (using brake and clutch cleaner most likely). As soon as I get mine done I will update further. David Did you get to the bottom of the issue ? Just curious to see if everyone has the same problem ? Quote Link to comment Share on other sites More sharing options...
Didge Posted February 7, 2017 Report Share Posted February 7, 2017 My wife's 2009 2.7 dj has just started doing this (less than a week) She took it to the Chrysler dealership 3 weeks ago because the engine light was staying on and the traction control would come on intermittently and it would not rev past 2500rpm (like a limp mode). the dealer plugged in and said it's putting up camshaft sensor and crank angle sensor code so replace these and will clear enginelight. have both sensors now so will fit tmoz. will let you know how that goes. im hoping it is related to the roll back when on an incline going from stationary position to moving position. doesnt matter if it's steep incline or not it s never done it before and it's not right let alone safe. She ends up having to rev it hard so it starts moving forward so she doesn't roll back into the car behind her. alot of posts about this problem and different suggestions. Will post up if problem is solved.. stay tuned. Quote Link to comment Share on other sites More sharing options...
Didge Posted February 8, 2017 Report Share Posted February 8, 2017 Latest update 2008 dj 2.7l mrs at supermarket jumps in car puts it in drive car revs up but no drive reverse nothing stuck in park i get there selector on gear box moving but no action . towed to dealer transmission kaput they say waiting on prices tmoz oh no. 80 000km and transmission non responsive cost of new tranny???? ugggggh Quote Link to comment Share on other sites More sharing options...
jkeaton Posted February 8, 2017 Report Share Posted February 8, 2017 Your vehicle is approaching 10 years old. Have you maintained the transmission per the manufacturers recommendations? Things break. Sorry for your troubles. Hopefully you got an extended warranty, or lifetime powertrain warranty. Quote Link to comment Share on other sites More sharing options...
Didge Posted April 30, 2017 Report Share Posted April 30, 2017 Yes so 2nd hand gearbox installed. car running fine. Engine light and traction light went out after sensors changed. 2 months ago. Quote Link to comment Share on other sites More sharing options...
larryl Posted April 30, 2017 Report Share Posted April 30, 2017 We didnt have 2008 Journey's.. began in 09 here Quote Link to comment Share on other sites More sharing options...
Didge Posted May 1, 2017 Report Share Posted May 1, 2017 Sorry sir manufactured year 2008 dj 09 jkeaton 1 Quote Link to comment Share on other sites More sharing options...
madcap Posted June 3, 2017 Report Share Posted June 3, 2017 Has anyone solved the problem of losing traction while starting Journey 2.0CRD Automatic transmission?? Quote Link to comment Share on other sites More sharing options...
