Front seat storage compartment stuck
Steve G.
My wife got the tab that you pull to unlock the front seat stowage compartment, stuck down inside the seat and we couldn't get it out. Needless to say that makes it impossible to open the compartment. Easy fix. Go behind the seat and underneath and you can put your finger inside the release to open it up. You will need another person the pull up on the seat for you as you will be behind and underneath the seat. Hope this saved you a trip to the dealer.
The strap should prevent the seat from latching if it gets stuck vertically behind the seat (the latch is right below the strap, so if it's pointed down, it should latch). If it goes off to the side, just get a smooth dowel to pull the strap back up from either side of the latch. There are always many methods to fix a problem.
Glad you got it loose.
