Hckynut56 Posted May 26, 2009 Report Share Posted May 26, 2009 After a recent oil change I reset the "change oil" reminder per the instructions (since shop forgot to). Warning now gone. But since then or soon after (didn't pickup on when exact time started). My interior warning chimes no longer work. You know, the dings you get each time you start the vehicle. Also I tested the seat belt reminder and the light flashes, but no sound. Did I do something wrong during the oil warning reset ?? Might I just have a fuse out, or real issue that will require a visit to the dealership ?? Thanks ! Quote Link to comment Share on other sites More sharing options...
sdeveau Posted May 26, 2009 Report Share Posted May 26, 2009 As annoying as those chimes are, they shouldn't be affected by reseting the "Change Oil" notification light. It may be something as simple as a fuse, it may be something else though. Your dealer *should* be able to tell you. Quote Link to comment Share on other sites More sharing options...
fradequero Posted January 16, 2022 Report Share Posted January 16, 2022 (edited) Do you repair the problem with the warning chimes? i have the same problem Edited January 16, 2022 by fradequero Quote Link to comment Share on other sites More sharing options...
2late4u Posted January 16, 2022 Report Share Posted January 16, 2022 try disconnecting the negative battery cable at the top side post for a few minutes then reconnect, kind of like rebooting your computer,,,hope it helps John/Horace 1 Quote Link to comment Share on other sites More sharing options...
