Range selector replacement
2009 SXT 3.5L. Symptom is intermittent no crank,just click when the key is turned to start. Will start in neutral when this happens when tried to crank in park. Sounds like the range selector switch.
How difficult is it to replace the range selector switch? Any procedures listed anywhere? And then how to refill the transmission since it appear to be inside the trans.
Thank you in advance!
