ecl Posted June 29, 2015 Report Share Posted June 29, 2015 I have a set of aftermarket rims from my last car but the bolt pattern is 5x114.3. I know ours are 5x127 and was thinking about just getting some wheel adapters but havent dealt with those at all before and wanted some opinions. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted June 29, 2015 Report Share Posted June 29, 2015 Personally I'll never use them again. Had some on another vehicle of mine. Ended up snapping wheel studs off. Coincidence? Maybe. But I have never had studs snap off on any other vehicle I've owned. Only the one with the spacers. Just my experience. Others will have different ones. Quote Link to comment Share on other sites More sharing options...
ecl Posted June 29, 2015 Author Report Share Posted June 29, 2015 Thanks for the input. I noticed one review from a place that had that same thing so I really don't know Quote Link to comment Share on other sites More sharing options...
dhh3 Posted June 30, 2015 Report Share Posted June 30, 2015 I have used them on two vehicles. If you decide to go with them, make sure they are hub-centric. This allows the spacer to be centered, exactly, on the hub, just like your wheel. Spidertrax makes the best spacers, IMHO, but I highly doubt that they make a set for the DJ. Do not get a cheap set with oval holes for the studs on your hub - you will only be guessing if they are centered. Quote Link to comment Share on other sites More sharing options...
ecl Posted July 1, 2015 Author Report Share Posted July 1, 2015 Thanks Quote Link to comment Share on other sites More sharing options...
Lawdog1911 Posted July 10, 2015 Report Share Posted July 10, 2015 As long as everything sits flat, (the wheels, spacer, hub) and its hub-centric adapters. Just make sure the wheel studs don't stick out past the spacer. I shaved mine about 1/8th" to sit flush. Quote Link to comment Share on other sites More sharing options...
